Eminence
Threads
- Search function not working (2 Replies)
- eminence skin (1 Reply)
- Spotlight widget?.. (1 Reply)
- How to Make Fallback Widget work the Same as in V1? (10 Replies)
- Where is the backup located (0 Replies)
- How do you access the power menu from the skin? (4 Replies)
- Why no Openweathermaps weather Maps in Eminence? (0 Replies)
- unable to change default colours (1 Reply)
- Widgets Fail? (5 Replies)
- Modifying details (0 Replies)
- mpaa/certification Problem (10 Replies)
- Fallback widget? (3 Replies)
- How to prevent widgets from showing watched items (3 Replies)
- Artist Slideshow doesn't work (1 Reply)
- HOW TO FORCE POSTER VIEW ON HOME SCREEN TO DISPLAY ONLY ONE POSTER (0 Replies)
- Skin backup on android box fails, no option to set location? (0 Replies)
- Where are Eminence Skin configuration files stored so that they can be migrated? (2 Replies)
- Custom Menu Items - Source Only (1 Reply)
- Numeric Values for ViewTypes (0 Replies)
- Full detail view? (1 Reply)
