Kodi Application
Sub Forums:
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168
Threads
- Improving Classical Music support in XBMC (4 Replies)
- [Ubuntu] xbmc icon broken for self-compiled xbmc version (10 Replies)
- add new context (or area) (0 Replies)
- NFC triggered playback (11 Replies)
- Error playing http live video link. Related to curl byte range? (0 Replies)
- [AMLCodec] What to do about problem that it's facing (8 Replies)
- XMBC add code (17 Replies)
- Find build depends when building with many core elements disabled (6 Replies)
- Copying a folder into Userdata (0 Replies)
- XBMC and Nginx compatibility issue [solved] (3 Replies)
- Special folders and uninstall (2 Replies)
- Education Build (8 Replies)
- remove some directories and files (1 Reply)
- Better xbmc.sleep()? (17 Replies)
- CDVDInputStreamHttp::Read not called? (2 Replies)
- ios 7.1 build failure (3 Replies)
- settings.xml - timezonecountry and timezone (2 Replies)
- Cheap 3D stereoscopic checkerboard mode for OpenGL (4 Replies)
- Building under OSX 10.9.3 and Xcode 5.1.1 (6 Replies)
- Apple allows direct access to the HW video decoder in iOS 8 (1 Reply)
