Apologies for the stupid question but I cannot find the scroll bar in the movie library. How do you scroll through your library fast alphabetically rather than going through the movies one by one. In other skins "up" or "down" reveals the scroll bar. On the Info Slide view for instance up reveals "view options", down reveals "recent items" and left and right scrolls through the movies one by one. Does it not exist in this skin? (using atv2)
Not in all views, no. Reason being, I wanted the other available action to open another window. Sorry.
igotdvds Wrote:Not in all views, no. Reason being, I wanted the other available action to open another window. Sorry.
Thanks for that igotdvds. That's a shame. One option to consider would be to have a scroll bar available when kiosk mode is on - which obviously would free up that up or down button that is used for view options. What do you think?
kealan
I have a scrollbar for the Info Slide view if you want to try it out. Here are links to the modified xml files. You can download them and replace the originals (you may want to make a copy of the originals if you don't want to keep the changes I made).
I'm on the latest GIT version just to let you know.
Link to modified includes.xml:
http://www.fileserve.com/file/DmqFkCN
Link to modified ViewsVideoLibrary.xml:
http://www.fileserve.com/file/N2JqdwZ
