2011-05-10, 02:36
2011-05-10, 22:00
Argh!!!
You're just teasing now!
I asked for the top view type in the request thread... will this make it to the addon repo for us 10.1 fools?
Bottom view with clearart is beautiful! What is the fallback if no clearart?
Really really hope so!
2011-05-10, 22:20
t2ffn Wrote:Argh!!!
Fallback is the default "no-logo" image.
I'll probably stay with Eden since I've changed so much for it. Feel free to grab from the GIT, most of the new stuff will work in Dharma too.
2011-05-10, 23:11
I think last time I checked it was just recently added that was broken...
Go on then, I'll just disable it on home screen.
Question (I'll know the answer soon enough): Does the recently added sub menu still work? This is a playlist, not a script right?
Great work, skin is light, fast and slick. My new fav. Really, well done sir.
2011-05-10, 23:36
i just pulled the latest version from GIT and i cant seem to find the TV show view in the second screen shot, has this been implemented yet?
2011-05-10, 23:48
I just pulled the GIT and don't have ANY of the above views... was I too quick?
It says version 1.2.0
Another observation over current addon version is there is a noticable delay betwen selecting Movies, and the movies coming up. This was the killer for Aeon MQ2 for me. Simplicity has always been quick, is it something to do with cache? Any scripts running when opening movies?
I'm on Acer Revo, 2Gb Ram, Live 10.1
2011-05-10, 23:50
oh good im not alone, that shit looks hot
2011-05-11, 02:56
You guys are too fast, lol.
I'll update the GIT tonight with even more new features.
2011-05-11, 03:39
igotdvds,
talk about awesome, this just keeps getting better and better. thank u so much for the work you do.
2011-05-11, 03:53
Thanks for the compliments!
New post, check out the main thread.
2011-05-11, 04:47
so when are these layouts getting added? i don't see them in the most recent update
2011-05-11, 05:09
samzstein Wrote:so when are these layouts getting added? i don't see them in the most recent update
Make sure you have "Use Landscapes" enabled.
Also, you can change view-specific things using the menu on the side of each view and going under Misc Options.
2011-05-11, 05:24
http://i.imgur.com/21xzG.png
i have use landscapes enabled, but the above layout never shows up/
gonna install the newest nightly build see what happens.
still cant seem to find the above layout....
got it...i feel stupid. again my apologies.
2011-05-13, 19:03
samzstein Wrote:http://i.imgur.com/21xzG.png
1. Enable "Use Posters instead of Banners for TV Shows" in Settings
2. Select Fanart as Viewtype in TV Shows
3. Disable Hide Fanart in Misc Options
4. Enable More Info in Misc Options
e voilĂ !
2011-05-13, 21:07
DFence Wrote:1. Enable "Use Posters instead of Banners for TV Shows" in Settings'
e voilĂ !
thanks DFence, figured it out for myself the other night
