2011-06-15, 06:47
After much tinkering I have come up with a solution which works great for me and will hopefully help others.
using EventGhost I created a python script which creates an eventghost event when the resolution changes, indicating what it has changed to. I then bound the event of it changing back to the HDTV resolution to a macro which closes and reopens XBMC. In my testing this solves the problem of XBMC being either at 1024x768 in the top left corner, or being blown up or frozen.
12/24/2011 Walkthrough:
Download and install the latest EventGhost.
Run EventGhost and create a new configuration. (File > New)
Right click on "Configuration Tree" and choose "Add Plugin"
Scroll through the list until you find "XBMC2" in the "Program Control" folder.
Choose "XBMC2" and press "OK". Adjust the settings as needed, no change is usually needed since we're running this on the XBMC PC.
Now select and copy the following code:
Right click on "Configuration Tree" again and choose "Paste"
Now save this configuration somewhere (File > Save)
If you want this to run on startup there is an option to enable that under File > Options...
That should do it! Merry Christmas!
9/11/2011 UPDATE:
I've modified Hitcher's Version which toggles fullscreen instead of restarting XBMC. I've been using it and deem it better than my original Idea. :-)
--Restarting XBMC version--
You may need to change the paths or the timings in the macro to work with your configuration.
Paste the following two boxes of code into the eventghost tree and give it a whirl!
Old Solution that did not work for everyone or was not permanent:
So some people have had issues with windows 7 falling back to 1024x768 when changing HDMI sources or turning off their monitor/TV/Receiver. I was one of those people.
There is most likely a more elegant way to fix this, but this is pretty quick and painless.
1. Install tightVNC server on the XBMC PC
2. Turn off the Receiver/TV/Monitor
3. Log into the PC via VNC viewer (Behold your 1024x768 resolution!)
4. Open screen resolution settings and change it to whatever you want it to stay as (1920*1080 in my case)
5. Power your devices on and off as you like! Uninstall tightVNC server also if you're done with it.
Seems like windows 7 falls back to a default resolution when it has "no monitor" to output to, changing it while it is using that monitor saves it to the "no monitor." So now when it has "no monitor" it changes to the resolution you set to that, and so nothing really changes...
<?xml version="1.0" encoding="UTF-8" ?>
<EventGhost Version="1534">
<Folder Name="XBMC Resolution Fix" Expanded="True">
<Macro Name="Check TV">
<Event Name="Main.OnInit" />
<Action>
EventGhost.PythonScript(u'from threading import Thread, Event\nfrom win32api import EnumDisplayMonitors\nfrom win32api import GetSystemMetrics\nprevres = \'1\'\n\nclass MyThread(Thread):\n def __init__(self):\n Thread.__init__(self, name = \'CheckTV_Thread\')\n self.event = Event()\n self.tv = False\n \n def run(self):\n global prevres\n while True:\n width = GetSystemMetrics(0)\n height = GetSystemMetrics(1)\n if prevres == \'1\':\n prevres = str(width) + str(height)\n if prevres != str(width) + str(height):\n eg.TriggerEvent(str(width) + \'x\' + str(height), prefix = "ResolutionChanged")\n prevres = str(width) + str(height)\n self.event.wait(1)\n self.event.clear()\n \n\nmt = MyThread()\nmt.start()\n')
</Action>
</Macro>
<Macro Name="SetDisplay and Toggle XBMC Fullscreen">
<Event Name="ResolutionChanged.1920x1080" />
<Event Name="ResolutionChanged.1024x768" />
<Action>
System.ChangeDisplaySettings(1, (1920L, 1080L), 60L, 32L, False, False)
</Action>
<Action>
Window.FindWindow(None, u'XBMC', None, None, None, 1, False, 10.0, 0)
</Action>
<Action>
Window.BringToFront()
</Action>
<Action>
XBMC2.ToggleFullScreen()
</Action>
</Macro>
</Folder>
</EventGhost>
9/11/2011 UPDATE:
PHP Code:
<Action>
</Action>
</Macro>
<Action>
</Action>
<Action>
</Action>
<Action>
</Action>
<Action>
</Action>
</Macro>
</Folder>
</EventGhost>
<Folder Name="Check TV" Expanded="True">
<Macro Name="Check TV" Expanded="True">
<Action>
</Action>
</Macro>
</Folder>
</EventGhost>
<Macro Name="RestartXBMConResEvent" Expanded="True">
<Action>
EventGhost.Wait(15.0)
</Action>
<Action>
Window.FindWindow(None, u'XBMC', None, None, None, None, False, 0.0, 0)
</Action>
<Action>
Window.Close()
</Action>
<Action>
EventGhost.Wait(3.0)
</Action>
<Action>
System.Execute(u'C:\\Program Files (x86)\\XBMC\\XBMC.exe', u'', 0, False, 2, u'C:\\Program Files (x86)\\XBMC', False)
</Action>
<Action>
</Action>
<Action>
</Action>
</Macro>
</EventGhost>
