Full Version: Can't Delete favourites
Hi
I've just bought a new 3tb ext drive and transfered my tv shows over, i used to have a separate home item for National Geographic, Discovery Channel, BBC, Concerts and History Channel, these were all made favourites then linked to their specific folder
Since i've changed ext hard drives, i need to make the new folders favourites but i have no idea how to delete my old favourites, i've searched and found that in Confluence you simply right click and hit delete, this doesnt happen in Night, so should i change skin to Confluence, delete the favourites, then change skin back to night and add new favourites?
Just wanted to ask beforehand in case i cock up somewhere
Open favorites
hover over selected item
Press 'C'
Select 'Remove'
Thanks for your reply but its not working for me
when favourites is up on the screen which ever item i hoover over gets highlighted in blue, i can also scroll up and down and each one turns blue,
if i press c i hear some small chimes being played like a door bell
any other suggestions to try
