i believe lots add-on out there isnt working anymore, and im searching those add-on is currently working on xbmc ios
. so please list the working add-on here that you are using already and share it, thank you!!
fabulous Wrote:i believe lots add-on out there isnt working anymore, and im searching those add-on is currently working on xbmc ios. so please list the working add-on here that you are using already and share it, thank you!!
For which one? The last official release? the last nightly release? the AudioEngine test release? The PRV branch release?
We don't want to keep lists like this, the whole idea with the addon system is "if its in the repo and not marked broken it is working"...
If you are using stable and something have gone broken report it and we will mark it as such.
If your using unstable it is bound to happen, if you expect everything to work just fine then you should _not_ be using unstable..
Ned Scott Wrote:For which one? The last official release? the last nightly release? the AudioEngine test release? The PRV branch release?
latest 06015 version 10.0.8
topfs2 Wrote:We don't want to keep lists like this, the whole idea with the addon system is "if its in the repo and not marked broken it is working"...
sorry i just wanna find out which is working which isnt, so i can just using the add-on is fine, or explore other add-on i don't have. thanks
No offense, but it seems to me that there are some plugins that work on other platforms - but NOT on ATV2, even running a stable release. I believe this has to do with the librtmp issue which as far as I know doesn't have a fix for ATV2. The Free Cable addon comes to mind but pretty sure there are others.
That said - there is *already* a thread attempting to list working addons for ATV2. If I run across that thread, I will post it here.
Yeah I guess, it would take someone to manage it and categorized it properly with all the variations, eg. ios versions (soon enough to be more than 2) and then the nightlies and its versions.
Its almost better for each addon to have a Compatiblity section in the introductions to their threads. That way their addon covers interests from all setups and appears professional.
eTip Wrote:No offense, but it seems to me that there are some plugins that work on other platforms - but NOT on ATV2, even running a stable release. I believe this has to do with the librtmp issue which as far as I know doesn't have a fix for ATV2. The Free Cable addon comes to mind but pretty sure there are others.
You focused on the wrong part of my statement, please let the team know which addons does not work on a specific platform. We can set so that an addon only works on a specific platform, thus we can make stable filter out the addons depending on librtmp.
activate Wrote:Yeah I guess, it would take someone to manage it and categorized it properly with all the variations, eg. ios versions (soon enough to be more than 2) and then the nightlies and its versions.
The addon.xml DOES this, the whole point of the addon system is so that users should not need to care. Obviously if you are using unstable we cannot garantue this. Short answer is, NEVER use unstable and expect stuff to work.
Sorry, my assumption was that letting the *creator* of the addon know that their addon wasn't working on a certain platform (which is what I have been doing) was the best path to follow. That way they can verify/confirm that it doesnt work on said platform....and if necessary pass that information on.
So what should we be doing? Not trying to stir up trouble, just trying to clarify how we can best help.
eTip Wrote:Sorry, my assumption was that letting the *creator* of the addon know that their addon wasn't working on a certain platform (which is what I have been doing) was the best path to follow. That way they can verify/confirm that it doesnt work on said platform....and if necessary pass that information on.
Sure that is even better, let them know and have them submit to repository the fixed one which have proper conditions in the xml
I am a new Kodi user. Before I realised an addon was labeled unstable, I had already selected install. Kodi now crashes repeatedly and will not restart. I deleted Kodi, and reinstalled, but it still crashes as soon as opening.
Apparently the addon that broke Kodi is still somewhere on my machine. How do I get rid of it and get Kodi to run again?
Macbook Pro IOS 10.10.2
For the future. Don't cross post your problems. I have moved your other thread into the right section and answered your question there.
