Hi bit of a new user to XBMC, just wondered as I have a lot of movies. Is there a way of seeing what was watched last.
Just sometimes. I stop watching a movie half way through and then i may go back to it a day or so later. Sometimes I forget what i have been watching.
Just wondered if there was a option to see, last played, etc.
thank you.
Press the down arrow while you are highlighting Movies. I am pretty sure there is an option in the submenu. Or maybe it's just for recently added?
If this option does not exist, I agree that it should.
First, no you do not have that option in the movie menu. I would think this could be possible since you can "Continue" play from previous. I would assume this means that that information is somwhere in the DB and should be retrievable.
When I get some time I may try to find out more on this and where that information is held.
Thanks,
SoBBie
After review I found here:
http://wiki.xbmc.org/index.php?title=The_XBMC_Database
That there is a field in the DB under bookmark for "type" and the options are 0=standard, 1=resume, 2=episode. I think you could possible sort by that to find movies you have started to watch and then sort by "timeInSeconds" so see which movie you are the furthest threw.
Not sure how possible it is yet but that is some extra info for ya
You can create a smart playlist for movies that are in progress
LOL well that seems a LOT easier to me. Especially since you can put a smart playlist under "Movie" on the home screen.
Thanks,
SoBBie
how would one do that then?
>>X<<' Wrote:Do the same as the video below to create a smart playlist but when creating a new rule use "In Progress" "True"
http://www.youtube.com/watch?v=BWrYO3FuE...ideo_title
Can you clarify this a bit?
I see the part where I choose "In Progress", but where do I select/type "True"?
Huma Wrote:Can you clarify this a bit?
I guess you haven't even tried it because "True" will show by default
In the video I select two different options "Video Resolution" which is where you select "In Progress" and "Greater Than" which is where you select "True"
I did try it. I was referring to the "in progress" under Playlist Options-> Order by. Didn't even realise there was a In Progress option under the rules section.
I'll try this out now. Thanks a lot.
Are ok I'm with you now did wonder how you could miss it
