Full Version: Xperience 1.1 and Original Xbox?
Hello,
I have recently been trying to get Xperience 1.1 to work on my original Xbox but have had no luck in doing so.
I know for a fact that the Bravo Beta worked/works (I am using it now) and is quite buggy, which is why I would like to try to get 1.1 to work.
I have a feeling that it has something to do with the .xml file (in the beta, the xml was called skin.xml, whereas in 1.1, it's called addon.xml), so I tried to rename the addon.xml to skin.xml and replace the instances where "addon" was brought up within the xml with "skin".
I have also tried YRUSirius's solution (delete everything in the media folder except for the animations, custom images and flags folders, and move the textures and midnight xpr files to it).
Unfortunately, both methods didn't work, so I am asking for help from fellow XBMC users. Any help is greatly appreciated.
