I have banner icons enabled for tv, but they will not show up in the banner views(banner pannel) is there something that i missed?
I am using the svn version from the passion repo the icons I have will not work in the banner pannel view and the banner download function lets me see different icons but the downloads fail. I hope this clears things up.
Uploaded with
ImageShack.us
Hudson_Hawk04 Wrote:http://pastebin.com/uTGwTsWf
Hopefully this debug log helps things.
It looks like it can't load from the path:
DEBUG: GetImageHash - unable to stat url smb://BOB-PC/TV/D-Day 6.6.1944/banner.jpg
I did find this in another thread in regards to the error:
Quote:It seems that you need create credentials for your SMB Server/Share.
I did this by adding a new source, then it asked me for username and password. Then i checked "Remember this..." or somthing like that.
After that all my logo's started showing up again.
After that i saw that the credentials are stored in the passwords.xml file, which is located in:
[Windows 7] "\Users\Username\Appdata\roaming\xbmc\userdata"
[Ubuntu ] "/home/username/.xbmc/userdata"
Try it out, hope this fixes your problems.
thanks for the tip, it would appear that I got it working. The library is still scanning but I am beginning to see icons, I changed the content to none, removed the individual shares, then re added them, as of right now it appears to be working, no need to create credentials.
Strange.... Glad to hear it is working though.
ok, well I spoke too soon, kind of it seems now the behavior is limited to custom shows that I added via EMM and their respective banners and those that have multiple banners, I cannot change them, also for some reason the boondocks is not giving me an icon, however I can see alternates.
I think it has something to do with the logo downloader only pulling down either the first or last item, if memory serves something along those lines was mentioned.
still unable to load some of my custom banners for series I made in ember, but some of the icons i want to change, to better suit my taste, and I cannot get them to change to another icon.
http://pastebin.com/DX0fkDnf
So if you are in your library, select "I", then Get Thumb, you cannot Browse and select the new banner you want?
gave it a shot, no dice it still wont allow for the changing to a banner icons other than the one that is stored locally.
