Full Version: XBMC, lights and Tellstick. [Windows]
Developed some small piece of software that will pull the videoplayer state from XBMC then command the Tellstick to turn on/off or dim lights
http://code.google.com/p/xbmc-light-controller/
Please feel free to try out ;-) This is an early stage since I created it today, but feel free to try!
This is supposed to run on Windows with Tellstick plugged in.
Only tested on Windows 7 with Telldus software against XBMC Live on remote computer.
Have released version 1.0.0.7
Please comment if you find it useful :-)
Have release new version: 1.0.0.8
This release has "Minimize to tray" so it won't be in your way while running. :-)
This doesn't work with Eden Beta 1. I found this guide though, works like a charm!
http://www.satheesh.net/2012/01/09/xbmc-lights/
Nod
Hmm, that sounds weird. I will download a copy of Eden Beta and test myself and see if any protocols have changed or anything Nerd
I use this every day myself and it works with stable release Smile
EDIT: http://wiki.xbmc.org/index.php?title=Eden_API_Changes
The JSON API has changed with Eden, rendering current release useless at time beeing. Will look into an automatic version compare with correct JSON commands later.
Hi again, I have now updated the piece of software to support XBMC Eden.
Thank you for using this.
I only get this error message when I try to install this:
"Unable to install or run the application. The application requires that assembly Microsoft.VisualBasic.PowerPacks.Vs Version 10.0.0.0 be installed in the Global Assembly Cache (GAC) first."
I assume there is something else I need to install?
