Full Version: Changing the Homemenu backgroundpictures
Hello
Love this skin.
I was just wondering what size does the pictures has to be if i want to change the backgroundpictures on the menuHuh
What is the resolution of you TV?
Depends on what you want. I usually get the 1080p (1920x1080), but you can also go with 720 or any other size you want. it will just look funny if you try to put a 300x300. try to get it to fit the screen that you use. if you dont have HD then you would want to stick with a 4x3 ratio pic.
Smile
SoBBie
