Apple just dropped a new
firmware for the Apple TV2
If you didn't
block updates from apple...
XBMC will be crashing due to the new update..
there are a few issues with the new firmware so update at your own risk, see below...
Direct Download link for the new firmware:-
http://appldnld.apple.com/AppleTV/041-08...store.ipsw
UPDATES
09/27/11: Overflow now working on build 8F455.
09/13/11: Nightly build install issues with dpkg have been resolved, i.e. using CTRL+C when it hangs should work.
08/21/11: Build 8F455 has known issues with: RemoteHD plugin, Overflow and
unofficial build updates.
08/19/11: Seas0npass 0.7.8 has been updated to support
iOS 4.3 Build 8F455.
Jailbreak FAQ has been updated with build 8F455 info.
ox_eye Wrote:Is there a changelog available? Something new?
Only thing I've read is ability to "stream purchased shows from the cloud" and adding Vimeo.
i take it this will erase the jailbreak yes ?
Gj02 Wrote:i take it this will erase the jailbreak yes ?
Yes. Wait for a jaibreak update, and the test of xbmc on this new firmware.
Help! I'm new to here but just tonight my atv2 keeps crashing out of xbmc. I did have the updates enabled but have now disabled them, however it still keeps crashing out. Only on xbmc not on iTunes homesharing? Is there anything I can do to sort this out ?
Boogiedout Wrote:Help! I'm new to here but just tonight my atv2 keeps crashing out of xbmc. I did have the updates enabled but have now disabled them, however it still keeps crashing out. Only on xbmc not on iTunes homesharing? Is there anything I can do to sort this out ?
http://wiki.xbmc.org/index.php?title=XBM...shing_XBMC
Thanks for that Ned, I think you may have fixed my problem!
I get an error when i try to install updatebegone,
dpkg was interrupted you must manually run dpkg configure - a to correct the problem.
any idea how to fix this?? thanks
i ssh dpkg --configure -a and fixed the error but it keeps crashing
I just installed my new ATV2 yesterday, I did the error of immediately upgrading it. I have to wait until this version is jailbreakable to put XBMC on it? There is no way to downgrade this with something like tinyUmbrella, or changing the hosts file?
Thanks in advance
freddurrr Wrote:I just installed my new ATV2 yesterday, I did the error of immediately upgrading it. I have to wait until this version is jailbreakable to put XBMC on it? There is no way to downgrade this with something like tinyUmbrella, or changing the hosts file?
Thanks in advance
I did this exact same thing last night on a brand new atv2 as well, and you're not out of luck! Just run seas0npass on it as you would normally (see the faq's) and it should all work fine. Mine did. When it asks you if you want itunes to automatically restore, click yes, and other than that seas0npass does all the work for you (you'll need to push the buttons for DFU mode too, but it spells that out too). I think the only loss is if you already had xbmc on there, when we'd lose our settings. But since our atv's are both brand new, the jailbreakability must have been unaffected.
chibwack Wrote:I did this exact same thing last night on a brand new atv2 as well, and you're not out of luck! Just run seas0npass on it as you would normally (see the faq's) and it should all work fine. Mine did. When it asks you if you want itunes to automatically restore, click yes, and other than that seas0npass does all the work for you (you'll need to push the buttons for DFU mode too, but it spells that out too). I think the only loss is if you already had xbmc on there, when we'd lose our settings. But since our atv's are both brand new, the jailbreakability must have been unaffected.
What is the firmware version on your ATV2? All posts on the firecore forum indicate that Seas0npass does not yet work with 4.3 8F455.
