Full Version: skin.touched (touch screen skin currently iPad 4x3)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13
Do not install or use this skin unless you have either touch screen or a mouse connected or you will lose navigation and have to manually change to another
Touched is the default skin on touch devices in XBMC Gotham 13.0
All source code (including the original images and commit history) can be found on our github account at https://github.com/xbmc/skin.touched
Obvious changes in this version
Re-Added the big bottom buttons for fat fingers (only real feedback I got was that people preferred them)
http://img840.imageshack.us/img840/8273/...ot013k.png
Added skin settings to remove items from home and to also add some quick launch for video addons
http://img98.imageshack.us/img98/8836/sc...ot014x.png
http://img43.imageshack.us/img43/7805/sc...t015jw.png
Updated the context menu to use the new code which helps to make the buttons more visible for their "clickable" area
http://img24.imageshack.us/img24/2369/sc...t017sm.png
Added some Basic touch screen controls to the picture window. Next/Previous Image, Exit out of full screen, Show Image Information, Toggle display of Music Info if music is playing
http://img854.imageshack.us/img854/222/s...ot016u.png
Full list of changes since last public version (newest first)
Quote:*Added a Indicator that you are currently watching a video to list views (looks like a play icon where the "watched" tick would be)
*Updated the context menu to use the new code which helps to make the buttons more visible for their "clickable" area
*Added some Basic touch screen controls to the picture window. Next/Previous Image, Exit out of full screen, Show Image Information, Toggle display of Music Info if music is playing
*Added skin settings to make the "Videos" button always go to the root of the video file system
*Separated out Media Info toggle for Audio and Video Playback so you can have one on and one off
*Bumped up the version number a little
*Added "language/Chinese (Simple)/strings.xml" based on version 0.8.0 thanks too chrisyu
*Cleaned up and added a few more skin settings
*Added skin settings to remove items from home and to also add some quick launch for video addons
*Changed/Fixed: show focused category in settings in a different color
*Fixed: Close the player controls when stopping Karaoke
*Changed: Make sure we close the options submenus on window close Smile
*Added a shadow under the submenu buttons
*Removed the "View" button from the options menu since its in main buttons again now
*Fixed up the location size and scale of DialogKaiToast.xml
*Re-Added the big bottom buttons for fat fingers
EXTRA STUFF YOU NEED TO KNOW
* Technically gestures should also work on windows 7 with a recent git master build of xbmc but its not tested so use at own risk
* LINUX IS NOT SUPPORTED. Linux does not have the gesture API hooked up yet so you wont be able to navigate around your media with a touch screen its currently iOS and windows 7 only
* I suggest adding this to your advancedsetting.xml and starting with a fresh userdata dir XBMC's default is 512 and a 256 will make your thumbs load much quicker when scrolling and they never get displayed that big in the skin anyway see here http://wiki.xbmc.org/?title=Advancedsett...umbsize.3E
PHP Code:
<thumbsize>256</thumbsize
* I have also uploaded a nicer weather icon pack to my site that I recommend people use I got the original from here http://forum.xbmc.org/showthread.php?tid=50196 but modified it so it would work with Eden versions of XBMC, so all credit to Bob___ for making it weather.zip just copy it over and replace the same zip in /private/var/stash/Applications.CHXuVl/XBMC.app/XBMCData/XBMCHome/media while xbmc is not running
The old development thread is located here http://forum.xbmc.org/showthread.php?tid=105142 so you can see its development
Some Changes in this version from the old version include
Much better support for subtitles Nod you can now turn them on and off from the OSD (middle right) and also download new ones if you want with the subtitle script`
I would also please like people to start working on some translations now too so I can stick it in the official repo and maybe even make it the default iOS skin. you can find the language file here
https://raw.github.com/JezzX/skin.touche...trings.xml
nice one Jezz!!!
Just got my wife an iPad so this will come in handy Smile
Great work!
I'm running today's build of XBMC from:
http://mirrors.xbmc.org/nightlies/win32/
And 0.8 of skin.touched on Windows 7.
It works beautifully but lists don't scroll when I swipe my touch screen (or with my mouse). They just highlight whatever my finger is over.
Is there something I need to do to enable gestures on Windows 7?
I'm looking forward to using this as a touch screen jukebox.
Fantastic work Jezz_X, many thanks!
Looking and feeling good fella Smile I do miss the back button from 0.7.1 build the new one seems a little small for my big ass fingers. Excellent progess very exciting stuff for ios users Smile
Duplicate post fail lol I might as well use it to ask another question are there any plans to introduce a showcase view to the skin. I think a showcase skin with fan art support would be the icing on the cake.
lanroth Wrote:I'm running today's build of XBMC from:
I don't know like I said in the original post it should work in theory but maybe while enabling it on iOS Memphiz has accidentally disabled it on Windows 7 I don't have a PC touch screen so can't say if it does or not
lefty420 Wrote:Looking and feeling good fella Smile I do miss the back button from 0.7.1 build the new one seems a little small for my big ass fingers. Excellent progess very exciting stuff for ios users Smile
I'm going to look at dong a mix between the styles and see how it looks
lefty420 Wrote:Duplicate post fail lol I might as well use it to ask another question are there any plans to introduce a showcase view to the skin. I think a showcase skin with fan art support would be the icing on the cake.
Fanart is a Major ass slowdown on the iPad maybe its just my iPad 1 so any view with it slows it right down so no, no plans
Jezz_X Wrote:I would also please like people to start working on some translations now too so I can stick it in the official repo and maybe even make it the default iOS skin. you can find the language file here
I could do a dutch translation. Where should i send it?
you can just http://pastebin.com it again and link it here or do a pull request of github but the first is probably easier Smile
Jezz_X Wrote:you can just http://pastebin.com it again and link it here or do a pull request of github but the first is probably easier Smile
http://pastebin.com/KQTU4qkp
Dutch translation. Note: most dutch users are used to english words in the UI's they use so i kept some words instead of forcefully translating them to weird dutch words Smile
Added thanks
While viewing my movies library, the thumbnails are still only showing as a frame grab from the video, no the posters I've assigned through EMM. I'm using the same path substitution that I'm using on my ATV2 and Windows box, and those two are working just fine.
Help, please?!
no idea sorry maybe your log file can tell you what the problem is
