Full Version: Back Row issues with Cinema Experience with Trailers
Back Row issues with Cinema Experience with Trailers i have evertyhing setup the only issue that i have is this .i have trailers downloaded im using back row skin with cinema experience it will go fine thu my custom slide show intro fine but right after coming soon intro and it loads trailers it will have like some type of garbage or super impose part of the trailer while is playing this only happen on the trailers Huh any idea did some one experience the same thing? thanks for your time and consideration.
Sorry I've not experienced this myself - does it only do this with Back Row? Or have you tried it on other skins?
i have a dedicated converted 400 square feet garage in to a home movie theater with a 180 inch screen and blablabla also proud to only use Back Row is beautiful looks incredible nice and for me the best and i had decided to married that skin Big Grin but i guees i could try some other ones and see. thanks Sharpe for your time
Wow that sounds great Smile
It's just it could be an error for the Cinema Experience people to look into.
Cheers
