2009-11-09, 20:45
Pages: 1 2
2009-11-09, 21:21
spiff Wrote:xbmctex is deprecated.
ok, i'll switch to TexturePacker.
are .xbt files supported on the xbox?
2009-11-09, 23:29
ronie Wrote:ok, i'll switch to TexturePacker.
pretty sure thats a big fat NOPE
2009-11-10, 00:39
Jezz_X Wrote:pretty sure thats a big fat NOPE
so where do we go from here... ;-)
should skinners include both a .xbt and .xpr texture file?
when both are included, will the .xbt file take precedence on all systems (except the xbox)?
2009-11-10, 00:52
if you still think your skin actually works on the xbox (new stuff really isn't getting ported back) then just ship the xpr but soon (many months) down the track xpr support will be removed and it will all be xbt only but of course we will probably bump the skin version for that.
Honestly I would just make a final xbox version of your skin and move along with bigger and better but thats just me
2009-11-10, 01:25
Jezz_X Wrote:if you still think your skin actually works on the xbox (new stuff really isn't getting ported back) then just ship the xpr but soon (many months) down the track xpr support will be removed and it will all be xbt only but of course we will probably bump the skin version for that.
thanx Jezz_X.
if the xbox can't keep up with the latest and greatest in xbmc, so be it.
i have no interest in making/maintaining a separate (final) xbox version.
cheers.
2009-11-10, 01:45
thats why I said make it upload it and forget it (until someone decides to merge all the changes again)
2009-11-16, 05:25
Hi, I'm confused by all of this. I've made some minor mods to the xTV skin (to support fanart in the ListView mode) and I'd like to delve deeper by modifying it further to change graphics, and who knows where that might lead me. But I'm not sure what tool(s) I should be using. I'd like to extract the existing images from the textures.xpr file and it sounds like I should be creating new images into an .xbt file.
And why aren't the necessary downloads linked to in the first post in this thread (or easily downloadable from somewhere on xbmc.org)?
2009-11-16, 06:43
The xTV skins images are in the skinning SVN. You don't need any tools to extract them as they're just sitting their waiting for you to do something with 'em.
All you need is the TexturePacker app if you wish to compress them into .xbt. This, again, is in SVN.
Cheers,
Jonathan
Cheers,
Jonathan
2010-09-14, 11:12
hi,
yesterday i added dupe detection in TexturePacker. if you dupe an image, like is often done with studio logos etc, the data will only be stored once in the xbt files. just a heads-up if anyone notices their xbt files shrinking.
2010-09-14, 12:21
I wondered what the change to TexturePacker was - saves me asking, thanks.
2010-09-14, 22:40
Note - it's only enabled if you pack with -dupecheck option, which the addons bridge should be doing now.
Cheers,
Jonathan
Cheers,
Jonathan
2011-03-31, 19:54
Guys,
what to use in order to create XBT on Mac? Where is it?
2011-03-31, 19:57
pecinko Wrote:Guys,
you need to use TexturePacker. it's included in the xbmc source-code.
afaik there are no precompiled binaries for either mac or linux, meaning you will have to compile it yourself (which is not a bad thing to get into anyway).
2011-03-31, 20:40
ronie Wrote:you need to use TexturePacker. it's included in the xbmc source-code.
Thanks, Ronie
I know it could be useful but, ATM, it's like taking a mosquito with a hammer
Any kind soul willing to compile this little thingy for Mac?
I guess it doesn't change that often, so it will be useful for a while.
Pages: 1 2
