Full Version: Selecting "TV Shows" goes into "File Mode" on the SVN
I am having this problem when running the SVN but not when using the stable skin.
When I select "TV Shows" from the home screen it sends me into what I think is the "File mode" as I have to select "TV Show" again and then "Title" from a second menu before I get into my actual TV library. I only have the problem with this skin and have been through every setting I can find and nothing fixes it.
I did not always have this problem with the SVN, it started a while ago, maybe 3-4 months, but when this started I went to a different skin thinking this would be fixed soon. Well I am tired of the other skin and want to use Neon again. I assume there is a problem on my machine only since no one else has complained. Also I am using MySQL to sync my database and have a feeling this may be the cause but I really have no idea.
Some of my terminology may not be correct so let me know if any of that doesn't make sense.
Make sure you are using a nightly xbmc build and an svn version of the skin.
I'll try that, thanks!
Hi, I'm having the same issue since i upgraded to Eden.
Everything is fine under Confluence, but this problem appear in Neon and Cirrus extended v2.
Same problem on two machines...
http://pastebin.com/nGHp8XNQ
deubeul Wrote:Hi, I'm having the same issue since i upgraded to Eden.
You aren't running Eden, you are on Dharma:
01:08:28 T:3832 M:900845568 *NOTICE: Starting XBMC, Platform: Windows 7, 32-bit Service Pack 1 build 7601. Built on Mar *8 2011 (Git:e9e9099, compiler 1500)
