It would be great, if there was one hotkey to switch Audio tracks. Its always a pain in the ass to go through the menue to do that. Same thing with subtitles. There is already a hotkey to enable and disable them. Why not a key to select next subtitle? Would be soooo convenient
old post, I know,
....but recently I also have this need .... even in the XBMCbuntu no way to program two buttons on the remote-mce (the colored ones) for this purpose?
I am very surprised that this function, also very common in most loser dvd player, is not present in xbmc.
L = Next Subtitle
T = Toggle subtitle on/off
For "Next Audio Track" I think you need to add it to the keyboard xml, I usually replace the default A = AudioDelay with AudioNextLanguage
