Full Version: Strange problem
Hi Ronnie,
In T! svn running latest nightly build of pre-eden i can't use the movie button or any of the sub menu items nothing happens. i have to go into TV shows and drop down a level to get to movies.
Any ideas why?
Cheers
Derek
disable the 'integrate cinema experience...' option in settings > skin settings > scripts
Thanks a lot Ronie Sorted Smile
Great work btw, just gets better and better!
ronie Wrote:disable the 'integrate cinema experience...' option in settings > skin settings > scripts
Sorry for dragging this up. I was having same issue (solved with this info, btw, thanks for that) but am rather curious as to know exactly what is this "cinema experience"?
Pitbull_Raven Wrote:Sorry for dragging this up. I was having same issue (solved with this info, btw, thanks for that) but am rather curious as to know exactly what is this "cinema experience"?
it's an addon, you can read all about it here:
forum.xbmc.org/showthread.php?tid=87563
