I've decided its time to give Ember a new home. I've taken it upon myself to not only pick up the code where it was left off and attempt to continue development of it, but I've also create a new site for Ember so that it can be supported easily with forums, a wiki, bug and project tracking. Right now there isn't much to look at, but the source is there and available also on github. I plan to work on a release in the next few days.
Goals
To continue development of EmberMM, because its a great product, that in my opinion is the most stable and useful media manager available, I've tried all others, but yet still come back to Ember.
To provide a site where users can post questions, provide feedback, and in the long run provide an area where users can go for howto's, wiki forums etc.
Links
Main Website :
ember.purplepig.net Site is back with new host
GitHub :
https://github.com/bodrick/Ember-MM
Current Release :
[Release] Ember Media Manager 1.3.x
this needs to happen! and im glad its being picked up for development.
good luck with it.
Wow this is good news indeed. Hope all goes well, and of course good luck.
I was just thinking about trying some other managers since ember wasn't being developed anymore. hopefully i won't have to. good luck!
I've pushed out a new release that updates a few things. A quick summary :
1) Updated to the latest version of sqlite library
2) Updated to the latest mediainfo library
3) Removed the check for .NET within code at launch, not 100% reliable.
4) Cleaned up references
5) Other miscellaneous stuff I can't think off at this point
The downloads can be found at the project site
http://ember.purplepig.net/
is this based on the original EMM or EMM-r?
yes could you please clarify as asked by livin as well is this EMM or EMM-r?
In any case kudos to you and straight away a few requests=== ( will put on tracker as well)
1- Auto Update Library on addition of any new files
2- Auto scrape ( as per predefined parameters)
3- notify ( if seleceted e.g xbmc)
4- download extrathumbs AND extrafanart
Thanks for the effort bodrick.
Livin Wrote:is this based on the original EMM or EMM-r?
Its based on EMM-r since that was the code I could find, and seems to be the most current version available.
shaktoo Wrote:yes could you please clarify as asked by livin as well is this EMM or EMM-r?
Sounds like some good suggestions. I'll look out for them on the tracker, I have a few kinks to work out with my releases first, but then once I've gotten the kinks worked out I'll get to adding new features.
I updated from 1.2 earlier, now I'm getting errors
Quote:Title: Error
Message: Could not load file or assembly 'ICSharpCode.SharpZipLib, Version=0.86.0.518, Culture=neutral, PublicKeyToken=1b03e6acf1164f73' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
StackTrace: at EmberScraperModule.Scraper.ScraperObject.ProcessTVDBZip(Byte[] tvZip, ScrapeInfo sInfo)
at EmberScraperModule.Scraper.ScraperObject.DownloadSeries(ScrapeInfo sInfo, Boolean ImagesOnly)
Date/Time: 15/12/2011 17:29:50
bodrick Wrote:I've decided its time to give Ember a new home. I've taken it upon myself to not only pick up the code where it was left off and attempt to continue development of it, but I've also create a new site for Ember so that it can be supported easily with forums, a wiki, bug and project tracking. Right now there isn't much to look at, but the source is there and available also on github. I plan to work on a release in the next few days.
Goals
Links
Main Website : http://ember.purplepig.net
GitHub : https://github.com/bodrick/Ember-MM
Current Release : 1.3 available at project site
Great news! I look forward to seeing this great project gain some additional TLC
Both links to download are giving me files not found errors.
kri kri Wrote:Both links to download are giving me files not found errors.
Seems like the host was having some memory troubles, restarting the app fixed the problem for now, I might have to find a different solution for hosting the project, but hopefully I can figure out a way to improve performance etc.
