[Edit: I pasted a link to the debug log in my second post]
I just discovered this great software and it works fine with video files and music files. But I can't get neither the weather nor the streamed videos to work.
Now I don't care much about the weather so I'll ask you about the videos:
I'm getting this error each time I try to run a video add on:
"script failed! addon.py"
or "script failed! Plugin.video.tedtalk" etc...
So far I tried these addons :
4Players
Academic Earth
CollegeHumor
Google Techtalks
Ted talks
Youtube
So I guess I could try them all and get the same error.
I first ran it on the 10.1 version, then tried to install the 11.0 version just in case, with no success (every error remains).
Any idea how I could fix this ?
Thanks a lot in advance.
Antoine
Platypus Wrote:Hi,
4Players
Academic Earth
CollegeHumor
Google Techtalks
Ted talks
Youtube
Antoine
we need to see the log to be able to help, look in my signature for how to and make sure its a debug log
Hi Amet,
There you go :
http://pastebin.com/hMtkwHEV
I set up the debug mode then quit and restarted, then went to video addons and tried to start a few of them to record a few errors.
Check your network settings, System>Settings>Network. Looks like your not able to reach the internet.
I don't think so, In System>System Info> Network, it shows "Internet:Connected", and "link:Connected".
And in System>Network I don't see much I could change, I tried to light up every Http/UPnP option, but the errors remain.
I tried a bunch of other plugins to see what may work, and I could make the Aljazeera plugin work, it's got a "watch live" item that works fine, and a "news clips" that doesn't.
Though for national geographic for example I cannot watch it.
I hope it helps.
Platypus, i too have discovered these annoying errors.
i am not 100% certain, but i feel the problem may be that you may have an ip address not from the allowed region the site requires. i.e. not from USA
cause i have read others saying that the plugins work for them, but i continue to get errors.
i hope this helps.
Dam0
Thanks Dam0, but it seems it wasn't the issue. I could finally solve this problem.
I thought I was not using a proxy because it was disabled in Firefox and the installation of plugins through the xbmc system worked fine.
But in my windows parameter I found a ticked " use a proxy" checkbox. So I guess the proxy was default and firefox was bypassing it.
So I don't understand much of it, but at least now it's working
Platypus Wrote:Thanks Dam0, but it seems it wasn't the issue. I could finally solve this problem.
So I don't understand much of it, but at least now it's working .
Was this Internet Explorer internet options? or something in Windows?
I too cant get really any video add ons to work.
so just to clarify Platypus....
you live in a region with a valid ip range for these sites? and had proxy set to use other region, and have recently turned off the proxy, thereby re-enabling successful authentication with US based servers??
because id like to access some of these channels also at some stage.
thanks in advance,
Dam0
Platypus Wrote:I'm getting this error each time I try to run a video add on:
4Players
Academic Earth
CollegeHumor
Google Techtalks
Ted talks
Youtube
Antoine
I am using the post above because of the simliarity to my attempts. No addons will download or operate with the exception of al jazeera Live. Here is the log file I hope.
http://pastebin.com/rSrBv7Eq
Yes I know I am a noob, be kind
I am getting the same script error when trying to watch Academic Earth but only when I try to access by Subjects, everything else in AE works fine.
Running XBMC on Apple TV 2.
I don't know how to provide a log.
kegobeer Wrote:How to make a log file.
Thank you.
So I have restarted my Apple TV 2. Launched XBMC/Videos/Video Add-Ons/Academic Earth/Subjects...
And I get on the lower right corner the following error message:
Quote:Error
Script Failed: addon.py
Here is the log
http://pastebin.com/pAaQQ0n3
TheFirstKira Wrote:Thank you.
Here is the log
A quick update to my current issue.
I had just recently, last Monday, January 16, 2012 purchased my Apple TV 2 and jailbroke it with Seas0n Pass, installed nitoTV, XBMC etc. I installed and uninstalled a lot of stuff (brand new toy
Last night I decided to restore my apple TV and start from scratch only installing the software that I really want is absolutely necessary.
After a fresh install I am still having the same issue.
