look what I found on their
mailing list massage, they have you (xbmc) in mind
Quote:.......
Whether changing the display mode should be requested by the client but
not decided by the compositor. There are some applications which would
like to change the display mode to make itself fullscreen no matter
whether there is any other application. Like XBMC and Quake 3.
wayland can be future replacement for X. Maybe this topic should be in Linux-specific?
I'm so looking forward to a XBMC Wayland build! Especially on ARM.
(2012-06-06, 17:48)zAo_OSX Wrote: [ -> ]I'm so looking forward to a XBMC Wayland build! Especially on ARM.
On ARM, DirectFB support (
https://github.com/xbmc/xbmc/pull/454) can be a much better improvement since it aims to run without a windowmanager. For x86 Wayland seems to be the way forward but it will take lots of time before XBMC will make use of it. Probably, first the major distro's should start using it....
(2012-06-06, 19:00)Robotica Wrote: [ -> ] (2012-06-06, 17:48)zAo_OSX Wrote: [ -> ]I'm so looking forward to a XBMC Wayland build! Especially on ARM.
On ARM, DirectFB support (https://github.com/xbmc/xbmc/pull/454) can be a much better improvement since it aims to run without a windowmanager. For x86 Wayland seems to be the way forward but it will take lots of time before XBMC will make use of it. Probably, first the major distro's should start using it....
Thanks, but that article on github is closed and pronounced 'dead'.
Wayland support requires removing all X dependencies. I believe XBMC UI is OpenGL based and that means moving XBMC to OpenGL ES (which does not have X dependency) and probably the video acceleration layer needs to make use of non-X methods (like vaapi on KMS / wayland).
People using Nvidia will be out of luck as Nvidia VDPAU depends on X.
I have high hopes for Wayland + Ubuntu TV!
XBMC's iOS port already uses OpenGL ES.
butchered, totally meaningless half-arsed X11 implementation? WOHO! must jump on it right away... wait.
Who needs the aged X11?
There aren't any hw accelerated drivers for wayland yet...
i do. i run applications over the network all day.
(2012-10-28, 16:19)erhnam Wrote: [ -> ]There aren't any hw accelerated drivers for wayland yet...
There is actually:
http://www.youtube.com/watch?v=seVyi0y61...ure=relmfu
(2012-10-29, 09:54)spiff Wrote: [ -> ]i do. i run applications over the network all day.
I wouldn't stop XBMC for X as long as it is widely spread, but I think small HTPCs can profit a lot from Wayland.
Also, you can run X in Wayland.
(2012-10-26, 10:08)spiff Wrote: [ -> ]butchered, totally meaningless half-arsed X11 implementation? WOHO! must jump on it right away... wait.
Is there a way to run kodi natively over wayland?
