I have installed before XBMC 10.1 on my Windows 7 64-bit and wasn't opening when I was trying to launch it. Now that XBMC 11.0 beta 1 appeared I tried this one and it doesn't work either(doesn't open).
On my Kubuntu 11.10 64-bit it works just great.
Anyone knows how to solve that problem?
I presume you've tried completely removing and reinstalling it?
Maybe disconnect it from the net and disable your anti virus & firewall and try it again.
It works perfectly on my 4 windows 7 x64 systems.
I tried on a freshly installed Windows. It doesn't open in my case.
What error does it give?
Have you tried installing the latest video drivers (it needs that)?
Is XBMC generating a log file? Open the log by pressing Windows-R and in the Run dialog type:
"%appdata%\xbmc\xbmc.log"
(including the quotes). Click OK and the log should open in Notepad. Copy and paste the log into
http://pastebin.com/ and post the link it gives you here.
JR
Martijn Wrote:What error does it give?
It doesn't give any error, the wheel of the mouse is spinning(it shows that it loads something) than it stops and nothing appears.
I have the latest drivers for my nVidia video card.
jhsrennie, there is no log file. in %appdata%\xbmc are only some empty folders(Yes, I turned Show hidden folders and files on).
Btw, it turns my Task Manager unresponsive.
I did a restart, and before starting anything I tried starting XBMC and it worked. Strange. Maybe because of some other program it wasn't able to open?
You may think that I didn't had enough RAM but that's not true either because I have 8 GB and I never get to 50% usage.
aliancemd Wrote:I did a restart, and before starting anything I tried starting XBMC and it worked. Strange. Maybe because of some other program it wasn't able to open?
I have the
EXACT same problem.. Tried reinstalling, tried everything... only works when the computer is a fresh restart. Also, if I try to open the task manager the task manager doesn't respond.. :mad:
i have the same problem too xbmc only starts up when it is the first thing i open after booting up. when i try to open it later it doesnt start at all and freezes task manager
@sorsok55: we need to see a debug log. See post #5 above.
