nope, there's no easy way.
it's not a simple matter of just replacing the cd-case image.
you'll also have to adjust a lot of code to make sure the cd-cover will exactly fit the case,
since yours has slightly different dimensions compared to the one in T!
ronie Wrote:nope, there's no easy way.
Oh I see! You are not interested in replacing the existing one available in T! This would then be more like an original CD case for music!??
Goliath2000 Wrote:Oh I see! You are not interested in replacing the existing one available in T! This would then be more like an original CD case for music!??
nope, not at all :-)
early versions of T! had a cd case just like that,
but it was changed by popular demand to the transparent one.
ronie Wrote:nope, not at all :-)
Oh
oki, then never mind!
How about if I save the image in the same size as the existing one, where should I place the image then? Can't find the folder where all image should be.
Seems that everything is inside this "Textures.xbt"
