Full Version: editing the home menu
I've been playing with playlists | smart playlists and sets and can get them showing in the video section no problem.
Can I get a playlist | smart playlist to show in the movies view? or main menu at the side of movies?
Can I get a set to show in the main menu at the side of movies?
thanks
anybody?
you can edit the HomeSubMenu.xml to manually add your playlist, i guess...
if you want it as seperate item in the Main-Menu, then take a look at HomeMenu.xml
there's a nice tutorial (http://forum.xbmc.org/showthread.php?tid=89678) that explains how to edit the menu, it works similiar with the reFocus skin
regards
Doogie
