Im kinda new to this but when I go to install the addon there is nothing to install. I sftp into it and i can find where it would be but the addon.xml files are not showing up. there is nothing to click on to install the repo. any ideas?
Its like my apple tv2 isnt recognizing the file type. Ive watched all the videos and still isnt working.
what addon are you trying to install? First, see if it's in zip format, then go to "install it from zip file", install it.
Tell us what addon you have problem
bz06er Wrote:Its like my apple tv2 isnt recognizing the file type. Ive watched all the videos and still isnt working.
bluecop. and its not in a zip format, i think that what my problem is Im on a mac
its just in a addon.xml file not zip. any ideas?
What you need to do after installing the zip file is:
Go to your addons on atv2.
You should see Livestreams pluging.
Now, with the remote control hit Menu and hold for 4-5 secs until a sub-menu comes up
Go to Add-on Settings.
Go down and choose Source Type --> Enter URL and enter this link ===>
http://home.no/chj191/theStreamDB.xml and click OK.
Then Add source
Will ask you for a name.. Just leave as default ==>"theStreamDB".
Exit and you'll be watching Blackoutworms nicely categorize list.
Enjoy!
Hope that helps.
hmm. i cant find a livestreams pluging
Have you downloaded the zip file on your pc?
