Full Version: Aeon Nox 2.0.0 - White background
I don't know why but i don't get a white background with my rss ticker or menu items which make the items scrolling hard to read.
Here you can see my problem.
And this is how it should be as it says in the settings... and screenshots.
Now what i already did tried:
Several times of re-install where i removed everything again with Revo Uninstaller so no trace left behind and clean install but it just doesn't work out.
Is this a known bug?
Using XBMC 11 Eden Beta 3
Greetings and already thanks for the help! Appreciate!
Known bug, can be solved by restarting XBMC. Happens only after first install of the skin.
Thanks :-) Didn't know it was so easy fixed.
