Hi there hands down this is one of the best skins for xbmc I hav seen n tried but using it on ATV2 it just keep crashing n shutting xbmc yes I read FAQs where it said its heavy n I hav to disable few things I did disable those even half of view types but still it's crashing so pleaseeeeee Aeo-Nox help us ATV2 users or can someone mention here if this skin working for them on ATV2 if yes then how n what they did to achieve that
thanks
Razieal Wrote:Hi there hands down this is one of the best skins for xbmc I hav seen n tried but using it on ATV2 it just keep crashing n shutting xbmc yes I read FAQs where it said its heavy n I hav to disable few things I did disable those even half of view types but still it's crashing so pleaseeeeee Aeo-Nox help us ATV2 users or can someone mention here if this skin working for them on ATV2 if yes then how n what they did to achieve that
thanks
And how does XBMC behave when using other skins? It's very likely it is not a skin issue
Thanks for replying mate well all other skins works fine but this one keep crashing xbmc need fixing please help us out
I hav tried all other skins n they work fine with aeon it crashes mainly when loading something n it crashes every time when custom menu or custom submenu is launched going through some posts I hav read someone else mentioning that as well so there is a problem that need fixing
Please don't forget us ATV2 users
Same here, on ATV2 when you load a custom submenu item (video addon) or even a favourite from the main home screen, XBMC crashes and returns back to the ATV2 main menu. This also happens with Aeon MQ3.
Confluence works fine, loading the same addons via shortcuts (sub menu's). Addons include LiveTV, iPlayer, iPlayer favourites.
this is probably out of our hands. and do not think we´ll try to help unless you provide DEBUG LOGs, i don´t know how often i should repeat that.
First one happened when first loading xbmc main menu and the loading an iplayer favourite - crashed first time
http://pastebin.com/5w48gCJc
Second one happened when successfully loading 2 iplayer favourites and then loading a favourite from within the sportsdevil plugin.
http://pastebin.com/xpVisuYJ
Many thanks for your help...love the skin
hmm doesn´t show anything suspicious except
19:05:10 T:148058112 ERROR: Unable to find plugin
19:05:10 T:104898560 ERROR: GetDirectory - Error getting plugin://
19:05:10 T:104898560 ERROR: CGUIMediaWindow::GetDirectory(plugin://) failed
perhaps.
but better to post in the the fitting support section, not a skin issue.
Will post in general section. Btw this doesnt happen at all (never) using confluence skin. I can change to confluence now and it will not crash, change back and i can regularly force crash. Read something previously about changing theme wallpapers may cause crashes ?
