i searched the forum with no luck so starting new thread. I have a few old tv shows encoded in ogm with stereo audio in what i suppose is ogg. Playback gives no audio. With 10.1 it works fine. I saw another thread about ogg audio not working for music files so i guess ogg is the problem, not ogm.
jmarshall Wrote:Debug log please.
Enable debug logging from System settings, System, Debugging, and restart XBMC then wait a minute or two for all the startup tasks to finish. Play one of the problem videos for a minute or two then stop the video and close XBMC.
Open the debug log by pressing Windows-R and in the Run dialog type:
"%appdata%\xbmc\xbmc.log"
(including the quotes). Click OK and the log should open in Notepad. Copy and paste the log into
http://pastebin.com/ and post the link it gives you here.
JR
i hope this is correct, i censored the file name cause i'm paranoid these days, you never know where the copyright advocates are looking.
http://pastebin.com/gbyvV7yY
Looks like an ffmpeg problem:
[vorbis] Extradata missing.
It may be that this is something remedied in a later ffmpeg. Not sure. Do you have a snippet of the file that allows you to reproduce it but isn't too big? If so, create a ticket on trac and attach the file snippet along with the debug log. Assign to elupus.
Cheers,
Jonathan
yep i can attach the sample from the release, its around 2, maybe 3 mb, but it's pirated material, is that ok?
probably was okay until you said that.....
find a sample from a dvd you own...
2 or 3mb should be fine to attach to your trac ticket.
(See what I did there?)
wes paich Wrote:probably was okay until you said that.....
so no then? I had to ask you know cause in these days you have to be careful.
I'm having the same problem as OP. I just installed XBMC 11 eden and some of my older videos no longer have audio.
14:20:12 T:1180 ERROR: ffmpeg[49C]: [vorbis] Extradata missing.
14:20:12 T:1180 ERROR: Previous line repeats 272 times.
14:20:12 T:1180 DEBUG: ffmpeg[49C]: [ogg] max_analyze_duration reached
14:20:12 T:1180 DEBUG: FactoryCodec - Video: ff-mpeg4 - Opened
14:20:12 T:1180 NOTICE: Creating video thread
14:20:12 T:1180 NOTICE: Opening audio stream: 1 source: 256
14:20:12 T:1180 NOTICE: Finding audio codec for: 86021
14:20:12 T:1180 DEBUG: FactoryCodec - Audio: FFmpeg - Opening
14:20:12 T:2860 DEBUG: Thread CDVDPlayerVideo start, auto delete: 0
14:20:12 T:2860 NOTICE: running thread: video_thread
14:20:12 T:1180 DEBUG: CDVDAudioCodecFFmpeg::Open() Unable to open codec
14:20:12 T:1180 DEBUG: FactoryCodec - Audio: FFmpeg - Failed
14:20:12 T:1180 ERROR: Unsupported audio codec
14:20:12 T:1180 WARNING: CDVDPlayer::OpenAudioStream - Unsupported stream 1. Stream disabled.
I pasted the portion of the xbmc.log I thought would be helpful.
(2012-03-25, 21:27)gawman Wrote: [ -> ]I'm having the same problem as OP. I just installed XBMC 11 eden and some of my older videos no longer have audio.
maybe you can make a ticket with a video sample? and don't mention whether it's pirated or not!
How did this end up?
I have the exact same problem: no audio of ogm files after upgrade to Eden and I have the exact same errors in xbmc.log
Before the upgrade everything played flawlessly, after the upgrade only ogm (or ogg) audio doesn't work, all the rest is OK.
Also I am on a linux (Ubuntu 10.04) machine.
In my case, the file is legally copied from a DVD I own ;-)
The problem is I've ripped about 5 of these and I don't feel like going through the process all over again.
Afaik it isnt solved. I'm still using 10.1, everything works for me anyways and I like the old GUI better.
Finally made my way back to xbmc via pc, coming from an old xbox.
3 seasons of south park recorded in ogm play fine with sound on the old clunker (xbox) but not in the new "eden" xbmc!
wtf? let us use external codecs or something in windows! This isnt the only problem ive seen in my FIRST NIGHT of migrating. EVERYTHING played fine on my xbox, never had one problem since XBMP!
These videos play fine in EVERY single other media player I try! Been using this software for like 10+ years!
