Full Version: Playback failed. One or more items failed to play
I am running XBMC v.11 Eden beta 3. ATV2. Have had no problems really with any build. SMB to my Iomega NAS. Last night I tried to watch a video and the "working" animation in bottom right corner goes on for a very long time and then I get the error message "'Playback failed. One or more items failed to play check the log...". Nothing has changed in my settings or my NAS settings. I have the NAS DHCP reservation set so that the lease for that IP never expires/renews. Thought maybe it was not connecting but I tried deleting a movie and ran the update library function and it found it again and added to my library so I know XBMC is communicating with the share just fine. If it was not I would be getting another error message asking if I wanted to delete the missing file. Is there a common setting/error that causes this. Seems to have just happened out of nowhere. ATV2 with ATV Flash (black). I guess I could uninstal XBMC there and reinstall to see if that resolves it but wanted to check here first.
Post a log file. Beside that it is not recommended to have firecores media player installed with xbmc at the same time. Media Player might influence XBMC in a way where samba accesses might even crash XBMC. We can't change that (its because of ios internas) - so be warned that both are incompatible to each other.
Memphiz Wrote:Post a log file. Beside that it is not recommended to have firecores media player installed with xbmc at the same time. Media Player might influence XBMC in a way where samba accesses might even crash XBMC. We can't change that (its because of ios internas) - so be warned that both are incompatible to each other.
Thanks will post a log file as soon as i get home. By the way, firecore media player is not installed.
I'm at my wits' end here. I created the log file and I have tried several times on pastebin.com and pastebin.ubuntu. Once the text is there I submit and I get a lost connection error for IE explorer "Cannot display webpage". I have tried on both sites 10 times!!!! Is there no other way to get the log file on this site. Am I missing something?
log file is too big. Tried paste bin for smaller amount of text and it is fine. here is the log broken down into a few.
part 1 http://pastebin.com/iCkxqSft
part 2 http://pastebin.com/mig9YLMD
part 3 http://pastebin.com/819nT1pE
part 4 http://pastebin.com/W6CgsAfd
part 5 http://pastebin.com/BWtv4p86
part 6 http://pastebin.com/qb2eyxjj
Sorry i had to break it up. I've not done this before. I realize now I should have had the scan at startup setting off as that is probably the meat of it.
A reboot of the NAS drive seems to have fixed the issue as it was losing connection constantly. That would explain why XBMC was not giving me any "missing file" errors. Hopefully that is is as nothing else had changed prior to this happening.
Next time you have issues you might want to upgrade to the latest version, rc2 at the moment, there's a bunch of bug fixes in there... it's worth testing at least.
i don't even click on one of these links. Its allways nice when users with problems keep the logs small for us. But this one ... amazingWink
jd2157 Wrote:Next time you have issues you might want to upgrade to the latest version, rc2 at the moment, there's a bunch of bug fixes in there... it's worth testing at least.
I didn't mention it but I upgraded to the latest version and then wiped my library and brought it back in. I was still having the issue after doing this. It was the NAS share. XBMC was able to read it and bring the files back in but it would lose connection once it tried to play, I guess the handshake to the drive was there but then it failed (otherwise the "file missing error"). And sorry about the long paste I had "update library on startup" on so that was the meat of it.
