Hey Robla, Any ideas why I'd be getting "Dependencies Not Meet" error when I try to install via BlueCops repo? I'm trying to install it on an openelec install running eden beta 2. I have this runningvery well on my mac on the final release of eden. anything I can try? cheers
(2012-04-26, 01:40)InVAMPED Wrote: [ -> ]Hey Robla, Any ideas why I'd be getting "Dependencies Not Meet" error when I try to install via BlueCops repo? I'm trying to install it on an openelec install running eden beta 2. I have this runningvery well on my mac on the final release of eden. anything I can try? cheers
the requires section in addon.xml looks like this
Quote: <requires>
<import addon="xbmc.python" version="1.0"/>
<import addon="script.module.httplib2" version="0.7.1"/>
</requires>
the reason is httplib2.
If you have no repository installed that provides this package, this error message will be displayed.
you need to manually download httplib2 at
http://www.2shared.com/file/-d9Nvecf/scr...plib2.html
and manually install it (addons/intstall from zip)
Hi robla again great job on this.
Just wanted double check that the playoff games will show up in this?
The reason I ask is because the archive off the bulls game today is up on the nba website to watch but not on the addon.
EDIT: they do show up just takes a little bit
Damn rose getting injured again
None of the playoff matches will play for me and only 2 are displayed. NYK @ MIA & PHI @ CHI. I can play any game dated before today fine. I'm using version .0.0.6 of NBA League Pass.
Has anybody got anymore playoffs games displayed and are they working?
EDIT: ORL @ IND is now showing yet also won't play.
(2012-04-29, 07:16)jesseb05 Wrote: [ -> ]None of the playoff matches will play for me and only 2 are displayed. NYK @ MIA & PHI @ CHI. I can play any game dated before today fine. I'm using version .0.0.6 of NBA League Pass.
right, they list no archived playoff games up to now.. I guess they are as lazy as the NHL (took them a whole day on the first playoff game day to move the games to the archive)...
even on the NBA.tv website Saturday shows no games (04/29 at 8 a.m.UTC :-)
plugin updated to version 0.0.7:
I had to change the rtmp url for archived games (prefix 2 is for regular season, 3 means playoffs)
just reinstall from BlueCops repository
(2012-04-29, 18:06)robla Wrote: [ -> ]plugin updated to version 0.0.7:
This might just be a local problem, but I forced a repo frefresh and forced an update and I still only see 0.0.3. Is there any other way to manually get/install 0.0.7?
I had the same issue as you. Although it says 0.0.3 in the repo if you go to your video addons after updating it would be 0.0.7.
(2012-04-29, 20:24)jesseb05 Wrote: [ -> ]I had the same issue as you. Although it says 0.0.3 in the repo if you go to your video addons after updating it would be 0.0.7.
yep, as long as BlueCop doesn't update his addons.xml file with the new version number
it will show 0.0.3 but it will have the latest version I uploaded :-)
Should the playoff games from yesterday be working now after the 0.0.7 update?
Or are we still waiting for NBA to archive these? Is there a way I can check?
Thanks robla for the prompt updates.
(2012-04-29, 21:55)jesseb05 Wrote: [ -> ]Should the playoff games from yesterday be working now after the 0.0.7 update?
yes, they work just fine.. last night's games were available around 2 hours after they finished.. NBA seems to be back to normal..
strangely enough they seem to "forget" one game a night to archive in time.. on Saturday DAL@OKC took >12 hours... Sunday it seems to be the BOS game..
ok... now it's there (took 6 hours ;-)
I uploaded 0.0.8 and fixed the free game recaps for playoff games..
How can I install this ?
I got NBA League Pass in the repo. But it says DEFECT --> it has version 0.0.3
How can I install it ? Help please
(2012-04-30, 13:38)Blasterke Wrote: [ -> ]How can I install this ?
you need:
xbmc Eden (11.0)
BlueCop's repo installed
some repo which provides httplib2 (or manually download/install it.. link can be found in this thread)
(2012-04-30, 14:37)robla Wrote: [ -> ] (2012-04-30, 13:38)Blasterke Wrote: [ -> ]How can I install this ?
you need:
xbmc Eden (11.0)
I got :
XBMC Eden 11.0 --> Installed
BlueCop's repo --> Installed
httplib2 --> i've put this in Library/Applications --> install with zip but it doesn't do anything...
(2012-04-30, 14:45)Blasterke Wrote: [ -> ] (2012-04-30, 14:37)robla Wrote: [ -> ] (2012-04-30, 13:38)Blasterke Wrote: [ -> ]How can I install this ?
you need:
xbmc Eden (11.0)
I got :
httplib2 has to be extracted to your normal addon path ..
this is done automatically by using the menu "addons/install from zip"
the locations should be
Linux: USERHOME/.xbmc/addons/script.module.httplib2
Windows7 c:/user/USER/AppData/Roaming/xbmc/addons/script.module.httplib2
