Full Version: Addons not working on Eden 11.0 rc2
HI all,
I have tried to install XBMC Eden 11.0 rc2 on a windows XP and has installed but the add ons that I want do not work on there, like NAVI X and Aj's add on Filmi by nature...... They just do nothing when I press the mouse click.....
The add on 'TV on desi zone' gives me erros like script failed.
I have tried the previous verions like 10.1 but still kept getting the same errors.
I have managed to get a log report which I have attached below.
Please advise on how I can get these add ons working
http://pastebin.com
Many thanks
Ensure that these sites which the addons are connecting to are actually up and running (try to access them with a browser). Beside that you should post your addon questions in the addons forum....
cheers mate for the reply.....
I have checked the site on the web browser and they seem to be available.....
Even Navi x is not working and that is also available on the web.
sorry please could a mod move my thread onto the correct section ....
Many thanks
you try to run two add-ons;
1) one which is missing a dependency
2) one where you don't even have the main script
spiff Wrote:you try to run two add-ons;
cheers mate ...
how do I get the dependency in 1 ?
how do I get the main script in 2 ?
sorry I'm new to this but trying to learn as fast as I can.
I had installed Xbmc on windows 7 laptops and it had worked for these add-ons without a problem so donot know why this is causing a problem.
dependencies are usually resolved on installation time. did you install some loose .zip file or did you get this from a repository? since it's a third party add-on it may also very well be broken, i.e. doesnt declare the dependency.
the second is either a faulty installation, or another broken add-on.
spiff Wrote:dependencies are usually resolved on installation time. did you install some loose .zip file or did you get this from a repository? since it's a third party add-on it may also very well be broken, i.e. doesnt declare the dependency.
I got my addons from the link below so I think the files should be fine from there.
Quote:http://wiki.xbmc.org/index.php?title=Uno...positories
Just to be clear which is the second fault the Navi X or Aj addon ?
File "C:\Documents and Settings\John\Application Data\XBMC\addons\plugin.video.TVonDesiZone\TurtleMain.py", line 7, in <module>
                                                import TurtleService
                                            ImportError: No module named TurtleService
and
01:09:01 T:2676   ERROR: Python script "C:\Documents and Settings\John\Application Data\XBMC\addons\plugin.video.filmibynature\default.py" does not exist
01:09:01 T:2676   ERROR: Unable to run plugin Filmi BY NATURE
I have no idea what to do now cos I have got the add ons from the wiki.....
Any suggestions ?
Are these add ons built for XP or are they for Vista and upwards ?
i dont think the latest version of xbmc (rc2) is compatable with the latest version of navi. beta 3 is.
navi x seems to be working even on eden rc2 although I have installed beta 3 and tried the 'Tv on desi zone' with no luck.
'Filmi by Nature' does seem to work at all.
I do not know where else to get the add ons for these to work on my xp.
Any ideas please
