Full Version: [RELEASE] Tamil Video AddOn - TV Shows, Movie news, Live TV and Live Radio
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14
Hey Folks,
If you are interested in watching Tamil TV Shows and Movies check out my Code 'n X Addon. It scraps the links from a tamil hosting website. I try to keep the addon in sync with the changes in the website format but i always end up playing catch up. So please report any breakages here.
The plugin supports the following:
Live TV
Live Radio
OnDemand
Movie
Live TV supports upto 40 channels. OnDemand is recorded shows and it includes:
* Cinema (interviews, gossips, audio launch clips and much more)
* TV Shows
* TV Serials
* Comedy
* Entertainment (random youtube clips)
* Tamil songs (new, old, HD)
The best way to install the repo is to find it in superrepo:
http://superrepo.org/plugin.video.oliyumoliyum/
Check out instructions at http://superrepo.org/get-started/
My repo link:
https://github.com/codenx/codenx-xbmc-addons
You can install the repo manually by downloading the repository.codenx.addons.zip from http://github.com/codenx/codenx-xbmc-add...-2.0.9.zip and install in XBMC (Settings -> Add-ons -> Install from zip file)
Special shout out to the devs here, I took some of the video scraping code from some of the existing plugins. Big Grin
Thanks macha! This is amazing! Will check it out soon Smile great work!
thanks for this addon
Just found this...thanku.... Smile
Thanks for the add on
The plugin installs without any problem and I can see all the sub categories like Movie, TV Serial etc and and up to the episode level, but none of them is actually playing. The stream starts but then stops within couple of seconds.
Has anyone able to successfully watch any of the streams? I am using Eden Beta 3 build on Windows.
Hi atlind01, I've not tested this on Eden. Can you upload xbmc.log to pastebin after you hit the problem?
(2012-03-27, 20:41)codenx Wrote: [ -> ]Hi atlind01, I've not tested this on Eden. Can you upload xbmc.log to pastebin after you hit the problem?
http://pastebin.com/FAHYtsnT
Codenx, is the movie database is updated often ?
I just uploaded an update (1.0.7), the hosting site relocated the server and that broke the scrapper. It should be working again now. Let me know if there any issues.
Smile
Codenx, I don't find any latest movies added also can you help to remove the items which were not working ?
Many movies gives error..
Perfect plugin that I was looking for macha!
Codenx, Can you please update tweak little bit please. Most of the videos says that it has been removed by copyright. I know there are website like techsatish.net / cooltamil offer same tv serial contents.
On Eden I get the messaage that the addon does not have the correct structure.
all the links are saying the video was removed due to copyright violation. can you kindly help me with this problem
