Full Version: [RELEASE] Vice.com
Pages: 1 2 3
I've made an addon to browse and display videos from Vice.com. It's pretty straightforward, just install and run, no setup required.
This addon is Eden only
Github: https://github.com/paddycarey/plugin.video.vice
Download: https://github.com/downloads/paddycarey/...ce-0.3.zip
Any questions just ask Smile
Changelog:
0.3
- Added dialog before playing segment
- Various cleanup
0.2
- Added subtitle support
- Better multipart detection
0.1
- Initial release
Screenshots:
going to give it a go right now.. Smile
EDIT:
Works great nice job. Good to see another video plugin.
Using Linux, XBMC live on a minimal Ubuntu.
(2012-03-23, 01:38)wilson.joe Wrote: [ -> ]going to give it a go right now.. Smile
EDIT:
Great, glad it's working for someone else. It works for me but you're never sure until someone else tries Smile
Provided nothing crops up i'll submit it to the official repo soon.
Nice! It seems to have issues with some Vice videos (Vice Guide to the Balkans, The Jesus of Siberia.) Great to see a working Vice addon again Wink
Just tried those videos and they load fine for me though they do take a long time the first time.
I'd looked around and seen reference to a VBS addon in your thread but couldn't find it.
It does seem to work fine on the ATV2. On OSX, it gives me an error. Great work nonetheless, my VBS plugin broke a long time ago and it's nice to be able to watch the content again. Any chance for captions/subtitle support?
(2012-03-23, 02:55)maruchan Wrote: [ -> ]It does seem to work fine on the ATV2. On OSX, it gives me an error.
Strange, can you get me a log on OSX when you have time and I'll look into it?
(2012-03-23, 02:55)maruchan Wrote: [ -> ]Any chance for captions/subtitle support?
I'll look into it although i'm not really sure where to start with subs, I never use them.
Paddycarey, all I have to say is wow. I have been wanting this plug in for a long time. Thank you for all your hard work.
Zeee1
So I've managed to extract the subs which seem to be in dxfp format like so: http://pastebin.com/1eB9XHZ1
But I've no idea where to start and how to push these subs to xbmc
[EDIT] Figured out how but i just need to figure out a way to convert the subs into a format that xbmc will understand now
Something like this should work:
http://pastebin.com/Hmh2Hd2W
(2012-03-23, 21:53)maruchan Wrote: [ -> ]Something like this should work:
Thanks! That worked great Big Grin
Just pushed some changes to github which should hopefully enable caption support.
1. It's not optional yet
2. The new play mechanism is a bit buggy.
It'll take a while to fix these bugs but any brave testers can update to git HEAD now and give it a go Smile
Just posted a new zip in the first post with subtitle support if anyone wants to test
And another new zip, hopefully this time this one'll be good enough for a repo pull provided nothing crops up.
Any issues let me know.
Subtitle support should be more robust now, and the plugin should give better feedback as to what it's doing when loading.
First of all, thank you very much for this addon, I've been longing for this.
Some of my thoughts:
* There's always a "Next Page" even if it doesn't load anything new.
* There's no "Previous Page" (I know you can use the "..", but for me they are associated with going to the parent folder)
* For the the episode below (http://www.vice.com/en_se/hamiltons-phar...pisode-1-1) it doesn't start part 2 - can't find it either.
* The quality differs quite a bit.
XBMC:
Vice.com:
Thanks again and I'm looking forward to your updates. Smile
(2012-03-26, 18:39)werz Wrote: [ -> ]* There's always a "Next Page" even if it doesn't load anything new.
Should be fixed in the next version
(2012-03-26, 18:39)werz Wrote: [ -> ]* There's no "Previous Page" (I know you can use the "..", but for me they are associated with going to the parent folder)
I don't think I'll be changing this, don't see the need for a previous button at all.
(2012-03-26, 18:39)werz Wrote: [ -> ]* For the the episode below (http://www.vice.com/en_se/hamiltons-phar...pisode-1-1) it doesn't start part 2 - can't find it either.
That was fixed in Git if you want to update. The problem is that Vice has no standard naming scheme for parts of videos so it's hard to detect and find the next parts without a lot of brute-forcing or adding code for special cases.
(2012-03-26, 18:39)werz Wrote: [ -> ]* The quality differs quite a bit.
This is because I'm using the IPad mp4 stream as it's pretty simple to extract from their HTML5 player, if you know of a way to extract the higher quality rtmp streams from the flash player then patches are very welcome.
(2012-03-26, 18:39)werz Wrote: [ -> ]Thanks again and I'm looking forward to your updates. Smile
You're welcome Smile
Pages: 1 2 3
