Full Version: [WIP] HTPC-Manager Beta, Manage XBMC, Sabnzbd, SickBeard with one app
(2014-01-06, 18:40)MadClicker Wrote: [ -> ]
(2014-01-05, 19:38)styxit Wrote: [ -> ]- Widget showing disks stats from sabnzbd.
I don't know about a widget, but this morning I added disk stats to the sab module....total disk size, disk space remaining and to top it off total download remaining.
Added ETA and Sysload before I pushed the commit to my develop branch just now.
I added a new tab to the sabnzbd page. Here we can show disk usage and maybe later some other stats available from the Sabnzbd Api. This is not a dashboard widget yet, but this is a start. I will look into the system-diskusage and how maraschino did this some other time.
Here is how it is now:
I think that was a good solution.
Is there an possibility to add an saved nzb file to sabnzbd through HTPC Manager or an local saved file by file path.
(2014-01-08, 14:21)Svenvg93 Wrote: [ -> ]Is there an possibility to add an saved nzb file to sabnzbd through HTPC Manager or an local saved file by file path.
Sorry, not yet. I would like to have nzb-upload functionality some day.
(2014-01-08, 14:23)styxit Wrote: [ -> ]
Just configure the watched folder option in Sabnzbd. The file will be picked up as soon as it is saved.
(2014-01-08, 21:30)ylafont Wrote: [ -> ]
That's not really an option. Adding an nzb-file should be possible by using file upload in HTPC-Manager. If you are accessing HTPC-Manager over the internet from another location you can not easily mount a drive. There is an api function available in Sabnzbd too handle uploaded nzbs, we just need to use it.
@styxit I saw on the GitHub page that you are working on plex integration. I'm curious how it goes with the development.
(2014-01-08, 22:53)Svenvg93 Wrote: [ -> ]@styxit I saw on the GitHub page that you are working on plex integration. I'm curious how it goes with the development.
No i am not. You are probably referring to Issue #16. A while ago there was a guy working on it, but the current status is unknown.
Since i do not use Plex myself it would take me a lot of time to do this and i would never use what i created. There are multiple requests about features i would never use myself. If it is not too much work i sometimes work on it anyway, even though i will never use is. Adding Plex to HTPC Manager would take me a lot of time to do and test.
Like i said before; if there is someone else willing to work on Plex i would happily help them get started and answer their questions. After that i can merge their work into my master branch.
I have had HTPC-Manager running successfully on default port 8085. Then I decided I wanted to change the port (I know: if it ain't broke, don't fix it!) So I changed the port on the web interface settings and now I'm stuck. I can't find any settings file to change via command line! Any suggestions? Do I just need to reinstall?
-- port 9999
Now, if I were to go tinkering and want to change the port, how should I do it properly?
Don't change it to a port already in use.
Got it.
Another question: how can I add modules, like deluge and transmission, which have been created since I installed?
git pull
