I've newly installed Eden and Aeon Nox
But impossible to see any poster.jpg in the TV-Shows.
The "Use poster.jpg" option is enable.
Any idea ? Thanks in advance for your help
How are your sources configured ?
You could start by an example of your folder structure.
The TV-Shows are in a Samba share, after that all episodes are classified by TV-Shows and seasons:
e.g. smb://192.168.1.10/series/dexter/season 1/dexter_s01e01.avi
The folder.jpg are correctly saved in the TV-Shows folder but are not displayed in Aeon Nox.
I have the same setup (SMB shares), and it works. Try deleting textures.db.
Also there is new labels for thumbs available, so maybe that's it ? (post eden)
(2012-03-27, 09:14)Maxoo Wrote: [ -> ]I have the same setup (SMB shares), and it works. Try deleting textures.db.
deleting it won't help.
With post Eden hasn't been done anything with the skin.
poster.jpg should work just fine (not folder.jpg , that will only be of use when scanning your library from scratch)
poster.jpg is also in the folder.
Nothing is displayed by Aeon, the logo.png don't work either.
I have the same problem for a long time...
Same problem here since the update to Eden.
Even the Logo's are gone.
my TV Show stucture is:
<Shownames>\
- Seasons\...
(2012-03-29, 10:06)pred Wrote: [ -> ]Same problem here since the update to Eden.
<Shownames>\
- Seasons\...
it should be logo.PNG and clearart.PNG not jpg
I've been using eden builds for a while and it's all working fine for me
Logo.png is also at the good place. But nothing is displayed.
<Shownames>\
- Seasons\...
should be
<Shownames>\
- Season 01\
s01e01....mkv
etc
- Season 02\...
s01e02...mkv
I have exactly this configuration. No logo nor poster are displayed.
There is really a bug with Eden or aeon.
(2012-03-29, 19:10)rlanfran Wrote: [ -> ]I have exactly this configuration. No logo nor poster are displayed.
post a full
Debug Log on pastebin.com or paste.ubuntu.com and put the link here
