Working on a skin right now and want a button that will open the youtube addon and search for a movie trailer.
So say your looking at Avatar in the movie library and want to watch a trailer. You can click on a button that will launch the Youtube addon and search for "Avatar 2009 trailer" and return the search results for the viewer to select.
No idea if it is possible to script it or get something as close to the idea but would be great for people who don't store trailers on their hard drive and would prefer to stream them from youtube.
(2012-04-01, 14:39)krish_2k4 Wrote: [ -> ]Working on a skin right now and want a button that will open the youtube addon and search for a movie trailer.
My version from DialogvideoInfo.xml
<onclick>PreviousMenu</onclick>
<onclick>ActivateWindow(10025,plugin://plugin.video.youtube/?path=/root/search&feed=search&search=$INFO[ListItem.Label] - trailer)</onclick>
<visible>System.HasAddon(plugin.video.youtube) + [Container.Content(Movies) | Container.Content(Episodes) | Container.Content(tvshows) | Container.Content(MusicVideos)]</visible>
Will try this out. which skin is this from?
Worked like a charm! cheers djtoll!
edit: How do I make it so it returns back to movies view rather than videos when you exit out of search?
(2012-04-01, 21:04)krish_2k4 Wrote: [ -> ]Worked like a charm! cheers djtoll!
I think that is not possible - not with this macro version, and I cannot scripting
PS: My
Joggler Skin, but no release yet with this gimic.
ahh ok no problem, at least the main function works!
thanks for the help!
edit: still trying to figure out how to return back to movie titles screen, if anyone can help?
(2012-04-01, 22:07)krish_2k4 Wrote: [ -> ]ahh ok no problem, at least the main function works!
try this:
, return)</onclick>
From the documentation:
ActivateWindow(window[,dir,return])
Quote:Opens the given window. The parameter window can either be the window's id, or in the case of a standard window, the window's name. See here for a list of window names, and their respective ids. If, furthermore, the window is Music, Video, Pictures, or Program files, then the optional dir parameter specifies which folder XBMC should default to once the window is opened. This must be a source as specified in sources.xml, or a subfolder of a valid source. For some windows (MusicLibrary and VideoLibrary), the return parameter may be specified, which indicates that XBMC should use this folder as the "root" of the level, and thus the "parent directory" action from within this folder will return the user to where they were prior to the window activating.
tried that already, just returns you to the home view, I want it to return to movie titles since that is were the user navigates from.
(2012-04-01, 20:05)djtoll Wrote: [ -> ] (2012-04-01, 14:39)krish_2k4 Wrote: [ -> ]Working on a skin right now and want a button that will open the youtube addon and search for a movie trailer.
Trying to get a search done for vevo in a similar way but no luck so far.
<onclick>ActivateWindow(10025,plugin://plugin.video.vevo/?path=/root/search&feed=search&search=$INFO[ListItem.Artist],return)</onclick>
It just brings me to the vevo addon but does not search.
