2012-04-02, 10:23
2012-04-02, 16:22
why not just pressing "s"? (or a mapped button on the remote)
2012-04-02, 16:30
hi phil you are right, but i'm using the android remote and i can't press S or map any button. in first attempt i thought to use the shutdown menĂ¹ in the mediabar but i like my nox as clean as possible so i would use the power off as a submenu of system.
that's the matter. if you have another solution throught th android remote you are wellcome.
peppe
peppe
2012-04-02, 16:42
iirc the Android remote has a shutdown/exit command built-in
2012-04-02, 16:56
(2012-04-02, 16:42)Martijn Wrote: [ -> ]iirc the Android remote has a shutdown/exit command built-inyes? if i use the power button (in the bottom right corner) i can only exit from xbmc but not shutdown the system. i have to use a long pression, set something or do something else?
peppe
2012-04-02, 16:57
Android remote has S button. Press menu (android) on the remote control function.
2012-04-02, 17:06
sorry guys but i'm starting now to use the android remote.......
i don't understand if i press "menu" on the android remote i go back to the mediabar how i have to do to show the S pop-up menu?
now i'm going off-section.
peppe
peppe
2012-04-02, 18:02
I mean press menu on your phone, not on the remote.
2012-04-02, 18:21
now i understand, you mean the physical button on the device!
i use the software menu button.
i'm going to try.
peppe
Edit
yea!
i'm going to try.
peppe
Edit
yea!
