Full Version: Home menu background annoyance
Lets say I select tv shows on the home screen in Eden using aeon mq3 skin and then select a show like supernatural.
I see my nice supernatural backdrop, but when I try to navigate through the seasons and I go over the up directory(whatever its called, the selection to go back to tv shows menu), it shows the backdrop from the main home menu tv shows, which happens to be christina applegate.
Kind of annoying, anyway to keep this from happening?
You can remove the "up directory" in the appearance settings screen (I do believe thats where it is...)
Oh. Ok Thank you
thank you thank you thank you thank you thank you thank you!
your welcome
