I have two Italian movies which i embedded subtitles into, which are in .mov files, and in quicktime they play with the subtitles. But i just imported it into XBMC, and the subtitles won't play with the movie at all. I thought they were embedded into the movie, so how does this work? Thanks
Are you using XBMC v11? Have you tried to select the
subtitles (wiki) using the on screen display (OSD) menus?
Yes, I'm using the latest version. I did check to see if the subtitles were turned on, and they are, but the subtitles i'm using i embedded into the movie itself, so it should play automatically i would think. But they're not at all.
