2012-04-15, 11:08
2012-04-15, 11:09
Did you try \ again?
2012-04-15, 11:55
If the above suggesting doesn't work, try moving your mouse back into the smaller XBMC window before pressing \ again.
I believe it's possible to disable the \ key so nothing happens when you press the button by mistake. Could be useful because this button is right above the ENTER button on most QWERTY keyboards. Don't know how to do this (possibly by editing the keymap.xml) but if you search for it on this forum i'm sure you'll find something
