Full Version: [Solved]TVHeadend crashing on startup
Hi all,
Hope its ok for me to get help with this here, the tvheadend forums seem pretty quiet. I've been using XBMC and tvheadend for about 6 months and until a few days ago it was all working fine. On startup tvheadend now crashes totally, the errors output I've pasted below.
[INFO]:dvr: Creating new configuration 'Std'
[ALERT]:CRASH: Signal: 11 in PRG: /usr/local/bin/tvheadend (git-8f76d0c) [54a95c68574e8b7c69120e61bfbfe72e11cd92cd] CWD: /home/datty
[ALERT]:CRASH: Fault address (nil) (Address not mapped)
[ALERT]:CRASH: Loaded libraries: /lib64/librt.so.1 /lib64/libdl.so.2 /usr/lib64/libavahi-common.so.3 /usr/lib64/libavahi-client.so.3 /usr/lib64/libssl.so.1.0.0 /usr/lib64/libcrypto.so.1.0.0 /lib64/libpthread.so.0 /lib64/libm.so.6 /lib64/libc.so.6 /lib64/ld-linux-x86-64.so.2 /usr/lib64/libdbus-1.so.3 /lib64/libz.so.1 /lib64/libnss_compat.so.2 /lib64/libnsl.so.1 /lib64/libnss_nis.so.2 /lib64/libnss_files.so.2
[ALERT]:CRASH: Register dump [23]: 00007f02405429d0 00007f02405429f0 0000000000000064 a3d70a3d70a3d70b 000000004f95db6c 000000004f95e5f8 00007f0240ab1b70 00007f0240aa0680 00007f0240aa0640 0000000000000000 00000000019afdb0 00007f0240aa0680 00007f0240a98ce0 0000000000000000 0000000000000000 00007fff85568cc8 00007f024915b93a 0000000000010283 0000000000000033 0000000000000004 000000000000000e fffffffe7ffbfa17 0000000000000000
[ALERT]:CRASH: STACKTRACE
[ALERT]:CRASH: /opt/tvheadend/src/tvheadend/src/trap.c:139 0x421b88
[ALERT]:CRASH: ??:0 0x7f02497037d0
[ALERT]:CRASH: ??:0 0x7f024915b93a
[ALERT]:CRASH: /opt/tvheadend/src/tvheadend/src/dvr/dvr_db.c:271 0x4268bc
[ALERT]:CRASH: /opt/tvheadend/src/tvheadend/src/dvr/dvr_db.c:359 0x426c3a
[ALERT]:CRASH: /opt/tvheadend/src/tvheadend/src/dvr/dvr_db.c:379 0x426c9d
[ALERT]:CRASH: /opt/tvheadend/src/tvheadend/src/dvr/dvr_autorec.c:509 0x429166
[ALERT]:CRASH: /opt/tvheadend/src/tvheadend/src/dvr/dvr_autorec.c:374 0x4295fc
[ALERT]:CRASH: /opt/tvheadend/src/tvheadend/src/dtable.c:86 0x406bbb
[ALERT]:CRASH: /opt/tvheadend/src/tvheadend/src/dvr/dvr_db.c:921 0x42781d
[ALERT]:CRASH: /opt/tvheadend/src/tvheadend/src/main.c:414 0x4051df
[ALERT]:CRASH: __libc_start_main+0xec (/lib64/libc.so.6)
[ALERT]:CRASH: ??:0 0x404749
Segmentation fault
I have recently updated my box, as shown its running tvheadend from opdenkamp built this morning (git 8f76d0c). Not sure if its relevant but I have glibc 2.14.1 installed (just because it mentions libc in the crash).
Would greatly appreciate any help with this!
Edit:
Just to let anyone know who's having similar problems, if i remove epgdb from the .hts userdata folder it is able to start up fine. There seems to be an issue with tvheadend and the data supplied by tv_grab_dvb_plus, using EIT data works fine.
Just to confirm this behaviour - I updated my system tonight and everything resolutely refused to work. Starting tvheadend from the command line, it would appear in the process list and then vanish shortly after... I saw the same behaviour restarting it as a service. However, removing ~/.hts/tvheadend/epgdata and I could restart the service, and then re-enable the PVR client in XBMC.
From /var/log/syslog:
May 21 21:09:34 XBMCLive tvheadend[23810]: dvb: Found adapter /dev/dvb/adapter0 (DiBcom 7000PC) via USB (480 Mbit/s)
May 21 21:09:34 XBMCLive tvheadend[23810]: dvb: Found adapter /dev/dvb/adapter1 (Conexant CX24116/CX24118) via USB (480 Mbit/s)
May 21 21:09:35 XBMCLive kernel: [1557158.066633] tbsqboxs2: tbsqboxs2_set_voltage 0
May 21 21:09:40 XBMCLive tvheadend[23810]: EPG: Injected 50644 event from disk database
May 21 21:09:40 XBMCLive tvheadend[23810]: dvr: Creating new configuration ''
May 21 21:09:40 XBMCLive tvheadend[23810]: CRASH: Signal: 11 in PRG: /usr/bin/tvheadend (2.12.99~pulse-6) [07f24a20ca129aaabd5d3dd2487a8f36b6477bc2] CWD: /
May 21 21:09:40 XBMCLive tvheadend[23810]: CRASH: Fault address (nil) (Address not mapped)
May 21 21:09:40 XBMCLive tvheadend[23810]: CRASH: Loaded libraries: /lib/tls/i686/cmov/librt.so.1 /lib/tls/i686/cmov/libdl.so.2 /usr/lib/libavahi-common.so.3 /usr/lib/libavahi-client.so.3 /lib/i686/cmov/libssl.so.0.9.8 /lib/i686/cmov/libcrypto.so.0.9.8 /lib/tls/i686/cmov/libpthread.so.0 /lib/tls/i686/cmov/libm.so.6 /lib/tls/i686/cmov/libc.so.6 /lib/ld-linux.so.2 /lib/libdbus-1.so.3 /lib/libz.so.1 /lib/tls/i686/cmov/libnss_compat.so.2 /lib/tls/i686/cmov/libnsl.so.1 /lib/tls/i686/cmov/libnss_nis.so.2 /lib/tls/i686/cmov/libnss_files.so.2
May 21 21:09:40 XBMCLive tvheadend[23810]: CRASH: Register dump [19]: 00000033 c0100000 ffff007b 0000007b b624a4f0 4fbba9f0 bfef2ca8 bfef2bcc b09a5948 b09a5130 b0992900 00000000 0000000e 00000004 00241228 00000073 00210286 bfef2bcc 0000007b
May 21 21:09:40 XBMCLive tvheadend[23810]: CRASH: STACKTRACE
May 21 21:09:40 XBMCLive tvheadend[23810]: CRASH: ??:0 0x80692ba
May 21 21:09:40 XBMCLive tvheadend[23810]: CRASH: __kernel_rt_sigreturn+0x0  ()
May 21 21:09:40 XBMCLive tvheadend[23810]: CRASH: ??:0 0x806e883
May 21 21:09:40 XBMCLive tvheadend[23810]: CRASH: ??:0 0x806e90a
May 21 21:09:40 XBMCLive tvheadend[23810]: CRASH: ??:0 0x807049c
May 21 21:09:40 XBMCLive tvheadend[23810]: CRASH: ??:0 0x8070d8a
May 21 21:09:40 XBMCLive tvheadend[23810]: CRASH: ??:0 0x804db77
May 21 21:09:40 XBMCLive tvheadend[23810]: CRASH: ??:0 0x8070713
May 21 21:09:40 XBMCLive tvheadend[23810]: CRASH: ??:0 0x806e003
May 21 21:09:41 XBMCLive tvheadend[23810]: CRASH: ??:0 0x804c06f
May 21 21:09:41 XBMCLive tvheadend[23810]: CRASH: __libc_start_main+0xe6  (/lib/tls/i686/cmov/libc.so.6)
May 21 21:09:41 XBMCLive tvheadend[23810]: CRASH: ??:0 0x804b411
May 21 21:09:41 XBMCLive kernel: [1557163.478858] tvheadend[23810]: segfault at 0 ip 00241228 sp bfef2bcc error 4 in libc-2.11.1.so[129000+153000]
I'll go and see if I can raise a ticket on PulseEight or Lonely Coder...
EDIT: Seems to be similar to https://www.lonelycoder.com/redmine/issues/996
New bug report for a more specific tvheadend version (2.12.99~pulse-6) filed here: https://www.lonelycoder.com/redmine/issues/1019
Looks like it's resolved now - no explicit bugfix, but it appears to be no longer apparent in 2.99-7~lucid/2.99.37.1332f9f.
