Hello,
I use tvheadend as pvr backend and it seems not all epg items are displayed? For example, there is no year, director, starring and country production information. All of them are available with tvheadend web interface.
Is this possible to add this to xbmc's epg window in Transparency skin as well?
uhh.. sry, missed your question somehow.
i'm not sure if it's possible...
it depends on whether xbmc imports this data and make it available to the skin.
do you know of any other skin that displays this data in the epg?
Maybe some other xbmc core developer can answer this (it seems dushmaniac is main pvr developer) ? Or, can you check this somehow and verify if this is possible? I have no idea what epg data is epxorted by tvheadend and what epg xbmc imports so I can't help, but I can see that not all of items available to view with tvheadend are present in xbmc.
Quote:do you know of any other skin that displays this data in the epg?
This is not checked, I don't know if any skin supports this. I can't check this for now (I'm not home) so I can't answer today. But it seems (as I remeber), Confluence don't display this too - but I'm not 100% sure about this.
