This is a
Modded version of Jezz's new Confluence Lite that will allow the user to add their own choice of items to the main menu bar.
Small Print - This Mod uses more resorces than Jezz's skin. This Mod is less stable than Jezz's skin. This Mod is slower than Jezz's skin.
Supported add-ons
These will need to be downloaded and installed by the user as the skin does not automate this.
script.xbmc.intro.movie XBMC's intro movie
script.cinema.experience - Support thread
Add-on Metadata Actors Limited Support ATM context menu only
Addon - Show Movie Sets Info - Needs webserver to be running
weather.wunderground-0.1.9 required for new weather panel
The prefered installation method is to download and install the repository from
HERE. Once Mudisle Repo is installed you will find Confluence Lite Mod listed under "skin". Using this method will insure all requirements are met.
The source code may be found on
github
Wiki Page started by
Kevjs1982 can be found
here
As of v1.1.3 all
wilson.joe themes are included with the repo install - Source and binary files may be found on his
Git Account
Users willing to help with language translations may request to help at
Transifex - Confluence.Lite.Mod
Have fun and
thanks to Jezz_X for a great skin
HERE are a few simple playlists to help fill out the main menu. They're not mine but are playlists I've come across while playing with various skins. Obviously the best place to extract and store them to would be into the directory ..\XBMC\userdata\playlists\video\
Various TV and Hulu playlists from wilson.joe
Very nice, like the idea of being able to choose what to have on the homemenu, and to call it what you want
im sure alot of confluence users will like this
I am having an issue, wont add my music playlists, doesn't even show them in the folder but their there. liking your concept here.
(2012-04-23, 23:44)wilson.joe Wrote: [ -> ]I am having an issue, wont add my music playlists, doesn't even show them in the folder but their there. liking your concept here.
It'll be the file extension of your playlist. ATM only looks for .m3u let me know what you're using and I'll do another entry on the select option menu, or alternativly pick up everything in the music playlist directory - although there is a potential for a lot of problems that way.
ahh, that explains it I got xsp in my music and video playlist folders.
and in one of the folders I got pls files for online radio stations,
those I just created a link to on the submenu to pop up the folder
in file mode so I could see the thumbs for each one of them.
(2012-04-24, 11:13)Mudislander Wrote: [ -> ] (2012-04-23, 23:44)wilson.joe Wrote: [ -> ]I am having an issue, wont add my music playlists, doesn't even show them in the folder but their there. liking your concept here.
Updated new version v1.0.1
Added Music Playlist extensions .xsp and .pls and options for Music Videos and Favourites
As always shout out if something's not working
Worked like a charm, thanks..
added the following to the DialogVideoInfo.xml at the end so I could edit the
genres of all videos..
<!--- EDIT VIDEO LIBRARY -->
<control type="button" id="101">
<description>Edit library</description>
<visible>container.content(movies)</visible>
<include>ButtonInfoDialogsCommonValues</include>
<onclick>XBMC.RunScript(script.library.editor)</onclick>
<label>Edit</label>
</control>
<control type="button" id="102">
<description>Edit Library</description>
<visible>container.content(episodes) | container.content(TVShows) | container.content(seasons)</visible>
<label>Edit</label>
</control>
<control type="button" id="103">
<visible>container.content(musicvideos)</visible>
<label>Edit</label>
</control>
and added cinema experience
<control type="button" id="14">
<description>Home Cinema Experience</description>
<label>Cinema</label>
<onclick>Dialog.Close(MovieInformation)</onclick>
<onclick>Playlist.Clear</onclick>
<onclick>RunScript(special://home/addons/script.cinema.experience/addon.py) </onclick>
<visible>Container.Content(Movies)</visible>
</control>
(2012-04-24, 23:56)wilson.joe Wrote: [ -> ]Worked like a charm, thanks..
<label>Edit</label>
</control>
<label>Edit</label>
</control>
<label>Edit</label>
</control>
</control>
very nice!! Any chance of getting the db-editor for music aswell ?
MrMills, I know the script.library.editor only does videos, is there one for audio?
Hey,Mudislander are you going to bring all the features of convergence, if
so I don't think it remain light.
(2012-04-25, 07:53)wilson.joe Wrote: [ -> ]MrMills, I know the script.library.editor only does videos, is there one for audio?
To be honest, at first I was just testing the main menu system as it was supposed to go into Convergence. But I've been hammering away at Convergence for over a year continually and it's feeling a bit stale, so will give it a bit of a break. I've now got this mod on my main system and am growing quite fond of it as it's fresh and clean. First thoughts were to keep it lite, but I keep thinking of various scripts that I'm used to using eg. Cinema Experience - Which will be an option on the main menu soon.The wife is also jumping up and down over not having the genre poster view she uses, so that'll have to come over. Right now I'm adding watchlist.script and script.randomandlastitems which I think will work well (Unless your whole main menu is full of playlists then the system will probably crawl) - So yeah probably not going to stay lite
I'll add script.library.editor in for you so you don't have to keep re-doing it, Do you prefer Cinema Experience in the videodialog though - I always prefered it on the home menu.
Mrmills - I also only know of the video DB script.library.editor
Okay, just curious.. Thanks anyway
(2012-04-25, 21:18)Mrmills Wrote: [ -> ]Okay, just curious.. Thanks anyway
If I figure a way out you will be the first I let know.
thanks for the update
found a small bug, when clicking on the suggested albums nothing happens, movies and tv-shows works fine..
(2012-04-28, 03:29)Mrmills Wrote: [ -> ]thanks for the update
Thanks, have found it and will fix it today.
Actually have found a couple of other bugs such as the home screen labels are sometimes doubled when you come back from the media player and I'm having a problem with the visible conditions of the random media from playlists - if you have under 10 you get blank squares. I know why this one happens, but we may have to live with it for a while.
