I got a really annoying issue
When ever i leave my apple tv2 for to long it freezes.
for example i am watching justin tv and i fall asleep when i wake up the next day i sort have to unplugg the power and then boot tether it again
almost every morning unless i decide to just use my computer to watch Justin tv.
When it freezes i cant select anything i can leave the stream everything is just frozen solid and the only way i could use it for me to unplug and then replug and then re boot tethered.
If any one could help me out that would be great
thank you
sorry for that i am new to ATV2 so i havent figured out the log, but am reading our link and ill get back to you guys asap
thank for the link
Don't sleep?
for the xbmc.log to work i need to enable debugging from the setting option and then go about reproducing the same issue ?
when i put the apple tv 2 to sleep it works fine when i pull it out its works with no issue
my issue is that i am playing something then my tv sleep and i obviously already fell asleep when i turn my tv back on its frozen on a picture and i cant do anything after that
Yeah, turn debugging on then try to leave it so that the error occurs, try not to do too much else so that it fills up the log.
okay ill go ahead and do this tonight so ill just play justin tv and go to sleep, i do have a question for you, if it does freeze and then i do have to go about restarting it and then boot tehter it again, will that log get erased ?
or would i have to get the log before i reboot ?
thank you again all for the help
The log will save as xbm.log and then when after you re-tether and boot if you start xbmc then it will save a new log as xbmc.log and move the old one to xbmcold.log. It always saves 2 logs, the complete last time that xbmc was run, and the current running of it.
so its best to re tether boot it and before i get inside of xbmc i should pull the log before it start a new one
is that right ?
You will have to do a tethered boot, then either go in BEFORE you start XBMC and get the one called xbmc.log or start XBMC and then get the one called xbmcold.log
well i think i did it right here is my log file
i had to but i followed your advice and that after it froze i re thered booted and before i went back into xbmc i had gone in and pulled the log file from
/var/mobile/library/preferences/xbmc.log
as the debugging screen suggests it aswell
ALSO it was so long i couldnt get it on pastebin to i had it linked to my dropbox account here is my log
https://www.dropbox.com/s/piys8rr6o0kd9lo/xbmc.log
i hope you guys are able to access the log if not let me know ill upload it to another site or something
@fariswheel: FWIW, This happened to me before upgrading to a recent version of the justin.tv plugin. I haven't experienced this issue post-update.
If the justin.tv plugin is outdated, updating it may fix this issue.
i will look into this and see if there is an update and see if there is if it does fix the issue up
