2012-04-26, 11:57
2012-04-26, 14:09
For video?
2012-04-26, 16:37
yeah
like big icons = 538
fanart 1 = ??
fanart 1 = ??
2012-04-26, 16:44
<views>50,51,52,54,501,53,502,55,56,57,58,59,500,510</views>
- Open up View_Videos.xml
- Find-> id="51"
- Locate-> <viewtype label="537">Big List 51</viewtype>
Thus view 51 has label"537" = "Big list"
- Find-> id="51"
2012-04-26, 16:46
ah brilliant thanks so much
just a quick one with the new quartz update does it now show a progress bar of video downloaded so far
e.i the buffer
e.i the buffer
2012-04-26, 16:50
It shows it if video is buffering. It hides it when buffer is full. If you want it all the time, open up DialogSeekbar.xml, locate
and delete line
<control type="progress" description="Buffer Bar">
<posx>200</posx>
<posy>4</posy>
<width>924</width>
<height>16</height>
<texturebg border="8">VideoOSD/VideoProgressBG.png</texturebg>
<midtexture border="0,8,0,8">VideoOSD/BufferMidd.png</midtexture>
<lefttexture border="6,8,0,8">VideoOSD/BufferLeft.png</lefttexture>
<righttexture border="0,8,16,8">VideoOSD/BufferRight.png</righttexture>
<info>Player.CacheLevel</info>
<visible>Player.Caching</visible>
</control>
and delete line
2012-04-26, 17:03
thanks again your a star all sorted now
cause i set my advanced buffer to "0" i like downloading the whole thing and i like seeing how far i have got.........
2012-04-26, 21:18
Run into a problem at work I was testing this and I don't have a 0 advancedsetting.xml buffer so it worked all ok at home though I do have 0 buffer set up so info player.cache level shows as full rather than what I have actually downloaded
Any help would be great
2012-04-27, 15:44
Well my guess is that setting it to zero disables buffer so there is nothing to show. I'm not aware of a control that would show download progress. You are better asking devs about this.
2012-04-30, 15:12
thanks for your help pecinko i managed to fix it i used this and now can see the progress cache as its downloading
<posx>200</posx>
<posy>4</posy>
<width>924</width>
<height>16</height>
<info>Player.ProgressCache</info>
</control>
