Hi everyone. I wonder if you can help. I running XBMC on ubuntu 12.04 with gnome-panel. When I open up xbmc in windowed mode everything works fine, brilliantly in fact, except the panel and title bar is still visible at the top which is a little distracting.
So I thought I'd switch to fullscreen mode. The problem is, I have two monitors (one 16:9 and a 4:3) and when XBMC displays in fullscreen it spans the output across the two monitors. So half appears on one monitor, and the other half appears on the other. It's been like this as long as I can remember testing XBMC on ubuntu. Is there any way to make it just appear on my right hand 16:9 monitor?
Any help would me much appreciated.
Update: If I disable my second monitor before opening XBMC it works ok. But it's a pain to have to do it every time, their must be another way.
i had this same issue aswell and i have an nvidia card
run
sudo apt-get install wmctrl
and open a new file and name it xbmc.sh (or what ever)
and in it put
#!/bin/bash
move_and_fullscreen(){
NAME='XBMC Media Center'
while [ -z "`wmctrl -l | grep \"$NAME\"`" ]
do
sleep 1
done
wmctrl -r "$NAME" -e '0,1280,-1,-1,-1'
wmctrl -r "$NAME" -b toggle,fullscreen
move_and_fullscreen &
__GL_SYNC_TO_VBLANK=1 __GL_SYNC_DISPLAY_DEVICE=DFP-0 SDL_VIDEO_ALLOW_SCREENSAVER=0 exec xbmc
allow it to run as a program
and run xbmc.sh (click twice)
use your "\" to switch between 2 monitor full screen/left monitor windowed/left monitor full screen/right monitor windowed/right monitor fullscreen
all credit goes to this man
http://wojnickitech.blogspot.com/2011/01...nview.html
Amazing! Thank you so much! Worked first time.
Another question, how put that script in my main menu, to replace the normal xbmc icon?
in termnial
sudo mv /usr/share/applications/xbmc.desktop ~/.local/share/applications/
sudo chown <username>:<username> xbmc.desktop
mv xbmc.sh ~/.local/share/bin/xbmc.sh
gedit xbmc.desktop
in the text editer change
Exec=xbmc to
Exec=/home/<user>/.local/share/bin/xbmc.sh
save
now you have an icon (this icon will only show in your side)
if you want for all users (do as sudo) place xbmc.sh into
NOTE=>Name it diffrent from xbmc (maybe xbmc_dual_screen_fix or something JUST NOT PLAIN XBMC)
and edit xbmc.desktop from
and edit like above, but you only have to change the "Exec" from "xbmc" to "xbmc_dual_screen_fix"
Thanks again. I don't have a /usr/share/bin so I put it in /usr/bin (duno if that's strictly linux fs safe or not), and I had to change exec to xmbc_dual_screen_fix.sh (notice the .sh), but it all works. Thanks so much.
I do wish that xbmc did this on it's own mind you, instead of having to hack it like this.
I had the same exact problem on my system with ATI Radeon/AMD Radeon and fglrx/Catalyst driver on CentOS 6.3. I have primary 4:3 monitor running 1280x1024 and secondary 16:9 TV runnin 1920x1080. I am spanning these using Xinerama. With or without Xinerama XBMC detected always only 1 screen and the only options I had were Full Screen #1 (no #2 was available ever) and Windowed. When running in full screen mode the XBMC always opened only on the 4:3 display. When running in windowed mode, I was able to maximize the window on the secondary screen but it had title bar. With the help of this thread and some others I was able to come up with script which moves XBMC on the secondary screen and disables/hides the titlebar. I wasn't able to use wmctrl toggle fullscreen since every time I did that, XBMC moved to my primary 4:3 screen.
The solution is actually two scripts.
The first script is to turn on and off the title bar for the active window
File window-toggle-decorations.py
#! /usr/bin/python2
import gtk.gdk
w = gtk.gdk.window_foreign_new( gtk.gdk.get_default_root_window().property_get("_NET_ACTIVE_WINDOW")[2][0] )
w.set_decorations( (w.get_decorations()+1)%2 ) # toggle between 0 and 1
gtk.gdk.window_process_all_updates()
gtk.gdk.flush()
The second script is to launch XBMC, position it on secondary screen and toggle the title bar. You have to toggle the decoration twice to actually turn it off. I had to also call the window positioning multiple times, since it doesn't always succeeds on the first or second try.
File xbmcfull.sh
#!/bin/bash
do
sleep 1
done
./window-toggle-decorations.py
sleep 3
wmctrl -r "$NAME" -e '0,1280,0,1920,1080'
sleep 3
sleep 3
sleep 3
sleep 3
killall xbmc
killall xbmc.bin
__GL_SYNC_TO_VBLANK=1 __GL_SYNC_DISPLAY_DEVICE=DFP-0 SDL_VIDEO_ALLOW_SCREENSAVER=0 exec xbmc &
move_and_fullscreen
Hope this helps somebody.
thanks SO much, rocker2344, been using xbmc since its inception on the original XBOX.
Now building the ultimate media center the script above worked. Thanks!
Ubuntu 12.04.3 LTS 64bit
Using ATI card with experimental drivers
XBMC running full screen on my plasma
While still using small display for browsing/etc.
Both screens set at 1920x1080
Xinerama and tear free enabled in AMD CCC (admin)
I tried the wmctrl script, xbmc full screen still tries to pan across both the screens
Mine is a nvidia graphics card as well. There is no "full screen #2" in xbmc settings. I'm using a laptop as the primary screen and a HDMI over to the TV as a extended second.
I know this is an older thread, but I'm having same issue as the OP.
(2012-04-27, 20:16)rocker2344 Wrote: [ -> ]allow it to run as a program
How do I get the xbmc.sh to run as a program? When I double-click on it, it just opens it text editor. I'm new to Linux (obviously).
Is there an equivalent (for fullscreen strecthing across both monitors) for Windows 7/8?
I have dual mon, but haven't been able to make XBMC detect the new to monitor spanning desktop resolution.
