Full Version: [MOD] CharacterArt, Logo and ClearART support with different View
Pages: 1 2 3
copied file and replace viewtype and copied logo in season folder and renamed it as character.png .....is that what i suppose to do mate? coz its not seem to be working ?
never mind restarted xbmc now its showing up n looks awesome mate just cant wait for your new mod keep getting better and better Smile
anymore in works?
steve can this be implemented in landscape view?
this view i marked the positions as well on the right above logo it will look awesomeeeee.........
Uploaded with ImageShack.us
View : Episode with CharacterArt support
A characterART appears on the Episode View.
How Do you use it ?
  • Make a backup of your Viewtype_Episode.xml.
  • Download : Viewtype_Episode.zip
    http://www.mediafire.com/?yzf581qejlp38uc
  • Put in The Neon skin folder
    XP: Documents and Settings\%userprofile%\Application Data\XBMC\addons\skin.neon.svn\720p
    Vista/Windows 7: Users\%userprofile%\AppData\Roaming\XBMC\addons\skin.neon.svn\720p
    Mac OS X: /Users/<your_user_name>/Library/Application Support/addons/skin.neon.svn/720p
    iOS: /private/var/mobile/Library/Preferences/XBMC/addons/skin.neon.svn/720p
    Linux: $HOME/.xbmc/addons/skin.neon.svn/720p
  • Download CharacterART on fanart.tv
  • Rename it to : character.png
  • Put it in the root of your tv show folder.
Screenshot:
Screenshots
How Do I create this view ?
I searched "logo" in the Episode view I found this :
- <control type="image" id="7016">
  <posx>20</posx>
  <posy>35</posy>
  <width>300</width>
  <height>116</height>
  <texture background="true">$INFO[ListItem.path]logo.png</texture>
  <fadetime>100</fadetime>
  <aspectratio scalediffuse="false">stretch</aspectratio>
  <include>Animation_HiddenByInfo</include>
  <include>Animation_Viewtype_Episode_LeftSide</include>
  <visible>Control.IsVisible(51) + [Container.Content(episodes) | Window.IsActive(videoplaylist)]</visible>
  </control>
- <control type="image" id="9016">
  <posx>20</posx>
  <posy>35</posy>
  <width>300</width>
  <texture background="true">$INFO[ListItem.path]../logo.png</texture>
  </control>
I simply change "logo.png" by "character.png" and the position (posx and posy) and that'a all !
  <posx>50</posx>
  <posy>510</posy>
  <width>200</width>
  <height>200</height>
  <texture background="true">$INFO[ListItem.path]character.png</texture>
  </control>
  <posx>50</posx>
  <posy>510</posy>
  <width>200</width>
  <texture background="true">$INFO[ListItem.path]../character.png</texture>
  </control>
i totally get your point bit confused about superposition? but smaller size will do as well mate
0r u think it can fit else where on screen n looks nice>?
View : Landscape with CharacterArt support or The Razieal's Landscape view Wink
A CharacterArt appears on the Landscape View.
How Do you use it ?
  • Make a backup of your Viewtype_Landscape.xml
  • Download : Viewtype_Landscape-v2.zip and extract it.
    http://www.mediafire.com/?ndps7pxus51f8w3
  • Rename it : Viewtype_Landscape.xml
  • Rename it : character.png
  • Download Logo on fanart.tv
  • Rename it : logo.png
Screenshot:
looks awesome mate........
tried anything else? if not then you should upload viewtype file cant wait
great work mate
The Razieal's Landscape view Smile
hahha @ razieal's landscape view
lemme try it n give u feedback Smile
copied file but getting strange behaviour when i switch to landscape view characterart appears just for a sec then disappers happening in all tv shows.......any reason or solution ?
restarted and refreshed xbmc library as well
actually problem is tvtunes when theme is playing the characterart doesnt show in landscape i just stopped theme music and characterart appears so here is our problem mate...can you please look into it thanks
yeah its conflicting with tvtunes just double checked..hope there is a solution to this its weird tho
btw characterart looks great in landscape perfect positioning mateSmile
Ok , I fixed it
=> http://www.mediafire.com/?ndps7pxus51f8w3
Razieal, I've got an idea :
I would like to create a rule. This rule is character.png = a group of character and create character1.png, character2.png ......
In this way :
In the razieal landscape view, we could have a lot of characters ( for example : Kyle, Kenny, Cartman and Stan)
In the episode view, we could have the group !
Tell me what do you think about it !
steve really thanks for fixing that issue its working fine nowSmile
as for new idea really i think its brilliant idea my only concern is do we have enough characters on fanart.tv for tv shows?
but still you should work on it and demo it
i was thinking i dont know if its possible but can we make character art show in shows landscape mode just like in episode landscape mode?
i mean this view and marked the area where it should look good
what u think
I agree, we don't have enough character but it a new feature! Be patient Wink Wait&See !
Check this
Pages: 1 2 3
