Full Version: How to get media flags to show up on the bottom?
Does anybody know the setting or the skin I have to use or change to get the information in the red box of the picture?Image
I'm pretty sure most have it - the default confluence has it, but the information has to be in your library in order to be displayed. I had my .nfo files created without this information and when I scanned into my XBMC library, it didn't display.
Once I changed my .nfo files to include the info and updated XBMC, it displayed correctly.
How did you change those .nfo files?
also, I have the information there, but i have to press "C" while over the movie then it shows me the information. I'm just looking for how to get it to show the information when I hover over it, next to the movie poster.
also, i found i had alot of missing flags, just playing the film for a second then exiting would fill in the blanks.
Matt
(2012-04-28, 20:50)matt77303 Wrote: [ -> ]also, i found i had alot of missing flags, just playing the film for a second then exiting would fill in the blanks.
Matt
Uhh, what?
If any of my films wernt showing the logos for say dts. If i played the film for 2 seconds then stopped the film. It would then show the logos.
Or is that not what you ment?
Matt
It's not the logos/posters. It's just that I want to see the information of the movie below like where the red box is without having to go to more info everytime.
Which skin are you using?
Mediastream redux
