Full Version: Confluence support of 576p and 480p flags
Hi guys
This may or may not be skin related, but since I havent had any responses in my other post over in general help, perhaps someone in here might know the answer. http://forum.xbmc.org/showthread.php?tid=131053
I am trying to work out if the reason I am not seeing the 576p and 480p flags is due to XBMC or the confluence skin (default eden version)
Raab
Based on what you posted there are a few things...
1) everything above xxx x 576 will show as 720p
2) 576p and 480p flags do not exist anymore...superseeded by "SD" flag
Ah. Well thanks very much for clearing that up! I couldnt find that info anywhere, where did you find out about it? I did search the net and the forums plus read the wiki Smile
where to set that "SD" flag ? Confluence default fonts are too small on my SdTv ?
We are talking about media flags here...
If you want to change the font size, check font.xml in 720p directory
